Towing socket 3
- Orvil
01 Jul 2020 15:44 #224340
by Orvil
Towing socket 3 was created by Orvil
Hi had my jimny3 few months or more and I where looking to tow a small trailer. It already had fitted tow bar and elec socket. So I plug in a lighting board but no response I no the boards OK tested on another vehicle. His there a relay that might need changeing just don't want to split all the socket down if there's something could be wrong else where. Cheers for any help.
01 Jul 2020 17:19 - 01 Jul 2020 17:20 #224344
by Scimike
Replied by Scimike on topic Towing socket 3
Hi
Unfortunately you are at the mercy of however the previous owner fitted the socket, it may / may not have additional bits.
You can wire the socket direct to the Jimny Wiring loom which is routed around the rear bumper. In this instance if your vehicle lights are working but nothing on the trailer board, then a poor connection may exist. I would check the earth of the socket first if all the lights on the trailer board don't work.
Alternatively you can fit a relay repeater which isolates the trailer wiring from the vehicle wiring. It's a small black box that will have a separate fused supply, in this instance you need to check the supply. The repeater can be located anywhere, mine is behind the rear passenger side trim panel, the fused feed is via a spur fuse in the interior fuse box.
This may need you to just trace the wires unfortunately.
Good luck
Mike
Good luck
Mike
Last edit: 01 Jul 2020 17:20 by Scimike.
- Orvil
01 Jul 2020 17:35 #224346
by Orvil
Replied by Orvil on topic Towing socket 3
Hi Scimike
Yer will check things out tomorrow abit long has no relays missed. Seen some thing about Jimny 3 pulling plugins apart and reconnecting with bridge loop of wire when going to use socket to get a live feed ?.
01 Jul 2020 17:41 #224348
by RainerK
Replied by RainerK on topic Towing socket 3
The tow bar sockets often corrode, outside and inside. The first thing I would do is to take it apart make a picture of the wiring and remove corrosion, clean, .... . This something that helps you anyhow, even if this is not the reason.
The next thing would be to measure the cables, check if the grounding is ok, etc. Sometimes the cables are not connected correctly.
01 Jul 2020 17:46 - 01 Jul 2020 17:47 #224350
by Scimike
It's possible if it's an OEM wiring loom, but that's another possible connection option. Most people just wire direct to the Jimny loom which passes through a hole passenger side rear, this then plugs into the rear bumper electrics. It gives good access to all the required light feeds, as such you don't need a separate supply feed, you trailer lights are simply in parallel with the vehicle lights. People tend to use Scotch lock connectors which are the devil's own and usually lead to light failure.
Last edit: 01 Jul 2020 17:47 by Scimike.
- Orvil
01 Jul 2020 17:55 #224352
by Orvil
I'm going to be busy I've ordered a new socket and bracket has it looks like it done its time and could do with a face lift. Thanks
Time to create page: 0.094 seconds
