Gen 4 Jimny 2018+ - General questions to other owners
03 Jun 2020 23:38 #223241 by crash486
mlines wrote:
Internal to Suzuki so no one has any numbers to quote.
bulletin Q-A6G-004
Do you know if this is universal or are there different numbers for different countries etc?
crash486
04 Jun 2020 05:57 #223243 by mlines
Universal
The following user(s) said Thank You: crash486
04 Jun 2020 11:50 #223254 by 300bhpton
Gadget wrote: Also, as mentioned by someone else, the auto headlight sensor is infuriatingly sensitive, to the point that it's effectively unusable.
I wouldn't say unusable. TBH if it turns the headlights on in daylight, the only way to know is if you happen to notice the small non-intrusive tell-tale on the dash. But you kind of have to be looking for it in daylight. I've never had anyone flash me or any other response.
I'm also not convinced the sensor works any different to most of the other cars on the roads with auto headlights.
04 Jun 2020 11:55 #223255 by 300bhpton
B3Hulk wrote: i am more inclined to believe a weigh bridge to be honest but your maths does make a lot of sense. I will go to get weighed again and see what they tell me. Most of my added weight is from the steel wheels and KO2 tyres which are down low. Plus, when I am not fully loaded with everything taken off/out except the roof rack and the lights, I definitely know I am under.
I did see a post before but I think it might of been deleted. They claimed that I am over weight on the roof and the metal vibrating is causing the ear pain which was an interesting theory but I know is not the case. I have had this noise/pressure happening even after I tested removing the roof racks and all its components.
I don't know why but I have a gut feeling it may be a mount causing my problem, which mount? I have no idea.
Wind deflectors could also cause your problem.
04 Jun 2020 12:01 #223256 by 300bhpton
B3Hulk wrote: I have had 3 different 4x4s with live axles from landcruisers to wranglers and none of them rock the same way that the Jimny did before replacing the suspension. Before anyone asks, yes they had stock suspension when I owned them. I am definitely familiar with how they are meant to feel and drive.
The issue with the massive amount of stock body roll and rocking side by side was an issue before I added any of those items. I know increasing the centre of gravity will amplify the problem which it did . But yet again, the problem was there before adding the weight.
The Jimny has a narrow track and a fairly short wheelbase. But tbh it isn't hugely different to past Suzuki models, Wranglers, CJ Jeeps and many a Land Rover.
Having been in lots of 4wd's, I couldn't tell you that the Jimny rides or handles worse or even that differently to most of them.
Ultimately I still think either you have a fundamental issue with your specific vehicle (been in a crash, bent axel, something...) or arguably more than likely the vehicle is 100% fine and it is entirely your perception.
There are multiple vids of people going round the Nurburgring in Germany with the Jimny, you can clearly see that even when being pushed hard on a race track, there is still very little lean going on.
04 Jun 2020 18:29 #223263 by Gadget
300bhpton wrote: I wouldn't say unusable. TBH if it turns the headlights on in daylight, the only way to know is if you happen to notice the small non-intrusive tell-tale on the dash. But you kind of have to be looking for it in daylight. I've never had anyone flash me or any other response.
It's rapid changes in illumination that's the issue, there doesn't appear to be any built-in delay before the lights turn themselves on then off again. Drive under a bridge on a sunny day and you'll flash the car in front as they cycle on/off rapidly. Every other car I've had with auto lights has a delay of a couple of seconds before the lights turn on, which avoids this issue.
Time to create page: 0.846 seconds
