Gen 4 Jimny 2018+ - General questions to other owners
  • B3Hulk
01 Jun 2020 06:16 #223098 by B3Hulk
crash486 wrote:
CC Baxter wrote: What little things annoy you?
"Transfer case chain noise in 1st. Know there is a fix but it doesn't last".
I have to ask Crash, what's the story with the remedial not lasting?
I haven't had mine done but if I did I would expect a fix to last.
Chris
There have been several people here in Australia that have had the fix applied. Initially the sound is reduced substantially but after a while it returns.
It doesn't appear to be a problem mechanically, just noisy. It may come to be a Jimny "feature" .
I'd still report it and ask for the fix though.
crash486
Damn really? I was hoping to take it in to get it repaired as the Diff oils are meant to be replaced at 15 xxxkms anyway. I will see if suzuki will charge me to see it and to determine if it falls under warranty .
Do you know what the recall/bulletin number is?
01 Jun 2020 11:26 #223107 by Busta
B3Hulk. Regarding noise, ears ringing, body roll and getting blown about by the wind, may I politely point out that you have placed a large, heavy, un-aerodynamic metal cage on top of your car? I'd be very surprised if you didn't notice a big improvement in all these areas with it removed.
The following user(s) said Thank You: 300bhpton
  • B3Hulk
01 Jun 2020 22:10 #223131 by B3Hulk
Busta wrote: B3Hulk. Regarding noise, ears ringing, body roll and getting blown about by the wind, may I politely point out that you have placed a large, heavy, un-aerodynamic metal cage on top of your car? I'd be very surprised if you didn't notice a big improvement in all these areas with it removed.
Don't worry , almost everyone has said the same thing and these were all issues before the roof rack. The rack is made from aluminum and I can easily lift it on my own.
  • Azathoth
01 Jun 2020 23:52 - 01 Jun 2020 23:55 #223134 by Azathoth
How comfortable is your ride?
No complaints on the front seats. I only find that the space between my elbow and the door is a bit small.
Car is pretty fun to drive. Yeah body roll is high and the tyres squeal if you do a tight corner at moderate speed. But it's part of the fun. It seems you are driving faster than you really are.
Do your ears ring after 15-20mins?
No, engine noise is quite low. I just find that the transmission is a bit noisy and there is a clear bang when i change gears. But i like that.
Do you have difficulty finding accessories?
Not really.
Do you have trouble with visibility?
The rear view mirror blocks a bit the view than other cars i had but it's not a big deal
Other than that it's really great.
A quite noisy car window motor. And the window glass vibrates if i keep open just a little.
The 1st gear issue. The lane changing warning and the collision warning sometimes goes nuts for no reason whatsoever.
Last edit: 01 Jun 2020 23:55 by Azathoth.
02 Jun 2020 01:05 - 02 Jun 2020 01:07 #223135 by crash486
Chris
crash486
Internal to Suzuki so no one has any numbers to quote. Not a recall, so hoping it's only noise.
Oh and I had the oils changed . Not going to wait for 15k kms.
crash486
Last edit: 02 Jun 2020 01:07 by crash486.
02 Jun 2020 08:10 #223137 by 300bhpton
I bet it weighs more than you think. Plus it is 'where' it is. Right at the top of the vehicle, way above its Centre of Gravity. It will essentially be acting like a pendulum when the vehicle changes direction.
If you truly had these problems prior to fitting the roof rack, then logically the only answers are:
1. There is something wrong/broken/misaligned on you particular vehicle
2. There never was a problem and the vehicle is 100% fine and it is all your perception and/or lack of familiarity with 4x4's
I'm not trying to be rude or knock your vehicle or experience. I just cannot relate even remotely to the points you say about the ride, handling and swaying side to side.
Is this your first 4x4 vehicle? Or more critically, is this your first live axle 4x4? And what are you comparing it to?
For instance, my p38 Range Rover (when on air factory air suspension) leans and rolls a lot more than the Jimny does. And on the flip side of this, I have also owned very low riding sports cars with firm suspension.
Time to create page: 0.608 seconds
