Automatic gearbox advice..
23 May 2020 06:58 #222710 by kirkynut
Replied by kirkynut on topic Automatic gearbox advice..
zukebob wrote: The auto should be at about 3000 RPM for 60 mph and 3400 RPM for 70 mph. Not being entirely stock I had to go back and check my original numbers in the Grim Jeeper website. The manuals are a bit lower geared and the numbers he gave are about right for the manual.
Output shaft speed sensor?
Not sure if your 188700 is the same code
Sorry Zukebob, I didn't see your reply as I was off Googling.
Whilst I have no experience with the auto Jimny, these figures seem a little low.
23 May 2020 07:24 #222713 by zukebob
Replied by zukebob on topic Automatic gearbox advice..
No problem Kirkynut. To be honest, I was hoping that Lambert would come back around to the thread. I think he has an auto that is stock and could confirm RPMs. I was always a little shocked at the difference myself.
23 May 2020 07:32 #222715 by kirkynut
zukebob wrote: No problem Kirkynut. To be honest, I was hoping that Lambert would come back around to the thread. I think he has an auto that is stock and could confirm RPMs. I was always a little shocked at the difference myself.
He's never far away! He's probably out in a field!
Lambert! Where are you dear Sir?
23 May 2020 08:55 #222721 by Lambert
Replied by Lambert on topic Automatic gearbox advice..
Whatcha. No it's not happy .70 in top is about 3400 ish from memory and 60 is just over 3000. That said I don't daily the spare Jimny and it's been a while since I drove it at speed but it's a much calmer time than the manual in Dreadnaught.
  • Jcg1694
23 May 2020 10:19 #222723 by Jcg1694
Replied by Jcg1694 on topic Automatic gearbox advice..
Morning guys. Gonna see if i can locate the transmission speed sensor and give it a clean and more than likely replace anyway, thanks for all the replies and advice! Planning on roadtripping in the jimny when all this lockdown is over with so needs to be tip top!
23 May 2020 15:34 #222745 by RainerK
Replied by RainerK on topic Automatic gearbox advice..
In the pictures you can see the rpms at about 100kmh so about 62mph of my 2015 automatic.
In 3rd gear they are 4800rpm and in 4th 3000rpm. I drove about 105kmh because the odometer shows a little too much.
Time to create page: 0.352 seconds
