ABS sensor bolt size?
- Jimx5
07 May 2020 06:07 #221970
by Jimx5
Replied by Jimx5 on topic ABS sensor bolt size?
I have replaced kingpin bearings and seals to both sides recently and in doing so destroyed the plastic collars for both sensors, i have had no problems by just fitting the sensors centrally.
But if anybody has a link or a cobble together of the collars i would be grateful.
Dave.
Dave.
07 May 2020 07:46 #221975
Use insulation tape. wrap it around and around until you get a snug fit
Replied by Riccy on topic ABS sensor bolt size?
Jimx5 wrote: I have replaced kingpin bearings and seals to both sides recently and in doing so destroyed the plastic collars for both sensors, i have had no problems by just fitting the sensors centrally.
Dave.
The following user(s) said Thank You: jackonlyjack
- Thank you received: 674
07 May 2020 07:48 #221976
Replied by jackonlyjack on topic ABS sensor bolt size?
+1 on the collars
@mlines
@mlines
07 May 2020 17:27 #221995
by j999pre
Grey pick up Jimny
Replied by j999pre on topic ABS sensor bolt size?
I drill through and use a nut and bolt. No issue next time round
Grey pick up Jimny
- NickR
11 May 2020 09:09 #222126
by NickR
Replied by NickR on topic ABS sensor bolt size?
Just to add a note in case it helps anyone out. My apprentice replaced the kingpins on the other side over the weekend, and sheared the other ABS bolt exactly as I had showed her how to!!
But, if you can get the old one out and clean the M6 threads, and you are replacing the swivel seal bolts as I was, then the old oil seal bolts are a perfect fit and length! That gave me plenty of spares to use
Both plastic collars broke where they are very narrow (why are they quite so fragile!!), but managed to re-use them. +1 for stocking them as spares.
Nick
Nick
11 May 2020 10:00 #222129
by Velocette
Replied by Velocette on topic ABS sensor bolt size?
Bit of a bonus on my 2016 Jimny. I've been undoing ALL the nuts and bolts underneath and cleaning/copper greasing the lot as a precaution. The ABS bolts were dealt with but I found that instead of a plastic sleeve on the sensor unit itself as on my 2006, this one has 4 fins or ribs which make contact with the orifice and don't grip or seize.
Time to create page: 2.030 seconds
