ABS sensor bolt size?
- NickR
06 May 2020 10:47 #221938
by NickR
ABS sensor bolt size? was created by NickR
Hi all,
I had my first try at kingpin bearings this week, and managed to shear the ABS sensor bolt as seems quite common! I have drilled and tapped it out, and I think I managed to clean up the original threads without too much damage, but am wondering what the size is of the standard bolt? I am surprised that I can't find it on the forum somewhere, but I want to be sure I pick the right length etc for a replacement.
The other side has had several extra applications of WD40, to try and avoid having to do it all again in a few days time!!!
Thanks in advance
Nick
Thanks in advance
Nick
- Thank you received: 706
06 May 2020 11:40 #221939
Replied by jackonlyjack on topic ABS sensor bolt size?
I'm pretty sure I used M6x15
- NickR
06 May 2020 11:50 #221942
by NickR
Replied by NickR on topic ABS sensor bolt size?
Thanks Jack,
M6 means I am on the original threads which is good news
Nick
Nick
06 May 2020 13:56 #221946
by Scimike
Replied by Scimike on topic ABS sensor bolt size?
100% sure it's M6 as above. I had to helicoil the backing plates on our Jimny back to M6 as both bolts snapped when I attempted to remove. Now replaced with stainless steel including the helicoil inserts.
- Thank you received: 2004
06 May 2020 14:53 #221952
Replied by Lambert on topic ABS sensor bolt size?
I happen to have a selection of m6 roof bolts with the double flat drive slot, a 16mm one is doing duty on my near side and is perfect.
- NickR
06 May 2020 17:02 #221961
by NickR
Thanks for the confirmation, guys!
I haven't found any suitable bolts in my various jam jars yet, so I have put it all back together without it for now - well, I watched while my daughter put it back together! I quite like the supervisor role!! Then we can get on with the other side and try not to break it as well! I will have spares by then hopefully anyway
I did notice that, when the sensor is in, if it is not perfectly aligned with the mounting bolt hole, the tip hits the sensor ring - there does not seem to be any possibility for adjustment. I know it has to be close (at least in theory - I haven't fiddled with ABS sensors before), and I hope that the new bolt will hold it in the perfect position, but has anyone else noticed if this is "normal"? The sensor has a plastic collar on it that has some slight damage from removal, but it looks like it is sitting very snugly and centrally in it's hole, so it is only rotation from the mounting hole alignment I am intrigued by. The car goes ( a few metres), stops and engages 4WD normally, so everything else checks out.
Nick
Nick
Time to create page: 0.104 seconds
