Window auto down stopped working
07 Mar 2020 20:34 #219563 by 300bhpton
Hi. Anyone with a Gen 4 have the auto down/up on the drivers window stop working?
The window goes up and down normally, so long as you hold the switch. But the one touch down/up seems to have stopped working. It worked last week.
Vehicle was in at the dealers yesterday for a headlight alignment check and fitting of the rear view camera. And today the auto down window feature isn’t working. Wondering if something needs resetting?
07 Mar 2020 20:40 #219565 by Soeley
I think this happens when the battery has been disconnected. Fully wind the window down and then straight back up, I think that cures it (but might be having a flash back to my iQ) :dry:
07 Mar 2020 20:46 #219567 by 300bhpton
Soeley wrote: I think this happens when the battery has been disconnected. Fully wind the window down and then straight back up, I think that cures it (but might be having a flash back to my iQ) :dry:
Thanks. Will give it another go. Did wonder if the windows needed to be reset. So did try this with both the drivers and passengers window. But maybe I didn’t do it quick enough.
07 Mar 2020 21:25 #219571 by Soeley
I was nearly there, hold the button for 2 seconds when the window is closed.
From the manual.
Pinching prevention function (if equipped)
The driver's window is equipped with a pinching prevention function. This function detects a foreign object that is caught in the window as it is being closed by AUTOUP feature, which allows you to close the window without holding the window switch in UP position, and stops the window from closing to prevent damage. A. WARNING To avoid injuring an occupant by window entrapment, check that no part of the occupant's body such as hands or head is in the path of the electric window when closing it. This function may not detect an object due to the size, hardness, or position of the object being caught in the closing window.
A.CAUTION
The pinching prevention function does not operate while you are holding the window switch in UP position. The pinching prevention function may not detect an object caught in the window just before the window is fully closed.
NOTE: Even if you cannot close the window by the AUTO-UP feature because there may be something wrong with the pinching prevention function, you can close the window by holding the window switch in UP position. If you drive in extreme off-road condition, the pinching prevention function may operate accidentally because the window reacts to vehicle jolting.
Pinching prevention function initialization When you disconnect and reconnect the lead-acid battery or replace the fuse, the function will be deactivated. In this condition, the AUTO-DOWN feature will be deactivated, while the AUTO-UP feature may remain activated. The pinching prevention function needs to be initialized.
BEFORE DRIVING
To initialize the pinching prevention function, use the following procedure: 1) Turn the ignition switch to "ON" position. 2) Open the driver's window fully by holding the window switch in DOWN position. 3) Close the driver's window by holding the switch in UP position, and keep holding the switch for 2 seconds after the window is fully closed. 4) Check the driver's window to see if the AUTO-DOWN/UP feature works. A. WARNING Whenever you disconnect and reconnect the lead-acid battery or replace the fuse, the pinching prevention function needs to be initialized. The pinching prevention function will not be activated until the initialization is completed.
If the AUTO-DOWN/UP feature will not work after initialization, there might be something wrong with the pinching prevention function. Have your vehicle inspected by a SUZUKI dealer.
2
07 Mar 2020 21:27 #219572 by crash486
Happened to me. Friend reset the limits by
1) winding to bottom, hold for 3-5 seconds
2) wind to top, hold for 3-5
3) recycle power off to on
Should work.
The following user(s) said Thank You: faisalmagnet
08 Mar 2020 10:53 #219587 by 300bhpton
Thank you. Those institutions worked :) bet this catches a few people out in years to come.
Time to create page: 0.124 seconds
