Jimny Modifications
- ColinTheViking
06 Mar 2020 08:44 #219462
by ColinTheViking
Replied by ColinTheViking on topic Jimny Modifications
I'ts hard to find offroading terrains where I am so it would mainly be road use and some greenlaning. so maybe -15 wouldn't be too bad?
06 Mar 2020 09:08 #219464
by 300bhpton
In the Land Rover world, offset is super important, because at trials events you need a very good turning circle. So we often run different offset front and rear, wider on the front to allow more steering lock.
I'd just go for what you fancy and not worry about it too much
Replied by 300bhpton on topic Jimny Modifications
Personally I struggle to see how wheel offset will really impact off road ability tbh. Unless it is being done specifically to fit a larger tyre.ColinTheViking wrote: I'ts hard to find offroading terrains where I am so it would mainly be road use and some greenlaning. so maybe -15 wouldn't be too bad?
The following user(s) said Thank You: ColinTheViking
- ColinTheViking
06 Mar 2020 09:52 #219468
by ColinTheViking
Do you know if -15 offset with 15x7's on 215/75's would be an issue with no lift?
06 Mar 2020 10:05 #219469
Replied by Daniel30 on topic Jimny Modifications
It will be ok
06 Mar 2020 10:12 - 06 Mar 2020 10:14 #219471
I think your worrying about it to much, sometimes the forum and Internet gives to much information, then it frazzles your brain like it does mine (which is not hard) if you get 215 and —15 offset the very worst scenario is a tiny trim off the back of the front bumper but I doubt you will even need this and don't worry about your bearings they will go at some point like all cars but nothing drastically sooner than a normal jimny
Last edit: 06 Mar 2020 10:14 by Daniel30.
- ColinTheViking
06 Mar 2020 10:36 #219473
by ColinTheViking
Thanks Daniel, bought the Jimny now so should be all set to start making some changes
Time to create page: 0.285 seconds
