How many miles to a tank? Gen 4
- Bill Portland
- Thank you received: 77
28 Feb 2020 11:10 #219183
by Bill Portland
Replied by Bill Portland on topic How many miles to a tank? Gen 4
What's the most anyone has been able to put into the tank? i.e. do we know that the tank really is 40 liters capacity? The most I've been able to put in is 33 liters
- Thank you received: 231
28 Feb 2020 12:00 #219185
by 300bhpton
Replied by 300bhpton on topic How many miles to a tank? Gen 4
I managed 34.53 litres last night, with 287.6 miles on the ODO.
I feel it would have happily done 300 miles and been safe. But you are driving pretty blind.
It's a real shame really, Suzuki aren't the only culprit. But I see absolutely no use of the 'Range' estimate on the computer. Because as soon as you get down to really needing to use it (low fuel), the bloody thing stops working. Knowing the estimated range after I've filled up, is actually of little practical use.
The following user(s) said Thank You: Bill Portland
- GeezerDan
28 Feb 2020 18:34 #219191
by GeezerDan
Replied by GeezerDan on topic How many miles to a tank? Gen 4
It's all to pot lol. Range said 61, went to work and back (34 miles), range said 60 miles. Fuel gauge was on 2 bars, thought I'd fill up and only got 27.76 litres in.
28 Feb 2020 18:59 - 28 Feb 2020 19:00 #219193
by facade
Replied by facade on topic How many miles to a tank? Gen 4
Fuel gauges are for indication only.
I just zero the A trip when I fill up, then top up every 150 miles (I know it will do 250, but £25 or so is affordable
I'd rather have had a temperature gauge if I could only choose 1.
Last edit: 28 Feb 2020 19:00 by facade.
- Grima
28 Feb 2020 19:44 #219194
by Grima
Replied by Grima on topic How many miles to a tank? Gen 4
Temp gauge is a waste off time. Just shows temp normal if a hose splits or hole in rad it jumps to over heat. you should check fluid levels regularly. Even with a small leak a temp gauge won't save you.
- Beaverhausen
28 Feb 2020 19:48 #219195
by Beaverhausen
Replied by Beaverhausen on topic How many miles to a tank? Gen 4
Must admit, were it not for the temp gauge on my '06 Jimny 2 weeks ago I wouldn't have realised the fan-belt had gone!
So, a temp gauge would be good on my new one, plus rain sensing wipers (I've seen a YouTube review and they have them in, so I'm annoyed that they were available), and that's probably about it. Oh, and a 6th gear.
Android Auto being crap isn't Suzuki's fault.
