Going into limp mode? Power loss?
- GF68
07 Sep 2019 07:33 #213245
by GF68
Replied by GF68 on topic Going into limp mode? Power loss?
Sounds exactly like the issue I had and it was coil pack/leads that fixed it.
I really struggled to find leads that were a good fit after market. So in the end but the bullet and bought genuine Suzuki leads at circa £50! Coil pack much easier to find, bought one locally and used it to identify which actual pack was faulty.
Note I ended up with slightly wrong ones from amazon despite them saying would fit, needed vin number to get exactly what was needed. But as others have said it is an easy job to do.
- invincible
07 Sep 2019 07:34 #213246
by invincible
Replied by invincible on topic Going into limp mode? Power loss?
thanks lambert , so the above ones are correct, its looks like they fit all the engines. my 1.6vvt swift engine will have em in, i,m thinking try the 1.6 first eh any thoughts folk
- Thank you received: 1983
07 Sep 2019 08:30 #213249
Replied by Lambert on topic Going into limp mode? Power loss?
If you have a set on the 1.6 it would be economical to swap those in first and confirm the fault is rectified and then when you swap the motor in get new ones for the 1.6.
- invincible
07 Sep 2019 21:09 #213275
by invincible
yeah good thinking bat man! a damn good tip idea lambert, cheers bud , i,ll try that. spot on .
- invincible
10 Sep 2019 14:30 #213357
by invincible
Cheers gf, ive started the 1.6 engine swap today so hope the fault doesnt follow. If it starts!! Did you find out that a coil pack was faulty?
- GF68
10 Sep 2019 14:49 - 10 Sep 2019 14:50 #213359
by GF68
Yes, in the end, tracked it down to a single faulty coil pack that was breaking down when hot. If you lived closer I would lend you a couple of spares that I now have so you could do the same!
Last edit: 10 Sep 2019 14:50 by GF68.
Time to create page: 0.170 seconds
