Going into limp mode? Power loss?
  • invincible
04 Sep 2019 09:16 #213114 by invincible
Going into limp mode? Power loss? was created by invincible
My jimny is cutting out when driving, feels like no power, then all of a sudden pulls again. Cut out this morning on way to site for longest time, busy a66 and no pull offs.I have a 1.6 that I desperately need to fit but think I need to find out the problem on this 1.3 before fitting as the fault will just follow? Im thinking electrical, perhaps a wire earthing? Guy in garage put snap on, diagnostic computer on it and it showed nothing? I need to get to a railway station later a prob wont make it. Maybe this engine is just about to die, any ideas on what electrical parts I could check, id be well grateful. Cheers in advance, liam
04 Sep 2019 09:46 #213121 by Lambert
If it's not giving a code and is intermittent I would suggest coil packs and leads. Most other things will give you a code.
04 Sep 2019 11:16 #213125 by facade
Could be crankshaft position sensor, these don't show a code, but the engine usually stops for a few minutes until it cools down.
  • invincible
06 Sep 2019 13:03 #213205 by invincible
Replied by invincible on topic Going into limp mode? Power loss?
thanks guys, coil pack and leads, where would i find these on engine i,ll try and swap em then, and crank shaft sensor will be in the engine so ok when i swap in the 1.6 then i,m thinking? cheers Liam.
  • invincible
06 Sep 2019 13:07 #213206 by invincible
No eBay APP ID and/or Cert ID defined in Kunena configurationnew ones of these then u rekon lambert? cheers Liam
06 Sep 2019 13:17 #213208 by Lambert
That's the ones. They sit under the black cover on the top of the motor. Dead easy to swap.
