Going into limp mode? Power loss?
  • invincible
11 Sep 2019 20:35 #213418 by invincible
Replied by invincible on topic Going into limp mode? Power loss?
cheers GF, kind thought bud, ive been on with the 1.6 again and swapped the coil packs fr0m the 1.6 so fingers crossed. Liam
  • Jim28
14 Sep 2019 12:38 #213516 by Jim28
Replied by Jim28 on topic Going into limp mode? Power loss?
I think I have the same problem my Jimny runs for a few miles then cuts out then starts after a few minutes and goes for another few miles before doing the same. Is it usually the coil pack that is to blame?
Jim28
14 Sep 2019 12:56 - 14 Sep 2019 12:56 #213517 by facade
That is usually the crank sensor between the alternator and the block. If you pour cold water on it when the engine stops it should restart within a few seconds.
Last edit: 14 Sep 2019 12:56 by facade.
The following user(s) said Thank You: Jim28
  • invincible
27 Sep 2019 13:11 #213931 by invincible
i swapped engines facade to the 1.6 and the all seems ok now i suspect it was the coil packs?? then had a leaking / blocked 1.6 injector which needed replacing and shes good now, burnt the cat converter out like so getting a new one under warranty thou , yippie! cheers bud , liam.
Time to create page: 0.210 seconds
