Re:New Gen Jimny Tyre size
- Andy2640
16 Aug 2019 17:59 #212179
by Andy2640
Replied by Andy2640 on topic New Gen Jimny Tyre size
Would be worried on wet days with 235's. Aqua planing on 215's is scary enough.
That wide surface area and low weight will make it very hairy.
Be careful in the wet and at high speed.
- cyberdriver
16 Aug 2019 23:56 #212185
by cyberdriver
Replied by cyberdriver on topic New Gen Jimny Tyre size
215/80R15 are within the limits for the original rim, smaller (height and width) than 235/75R15 so should be OK.
- aage
17 Aug 2019 08:24 #212189
by aage
Replied by aage on topic New Gen Jimny Tyre size
I don't worry about that. I have been driving 4x4 on big tires for the last 40 years or so. From 33 to 38 inch and yes its different but you get used to it as everything else. I look forward to try it out in the snow and its more slippery then the wet roads.
- Thank you received: 96
20 Aug 2019 05:30 - 20 Aug 2019 05:33 #212342
by DAGZOOK
Found this online today guys as I’m looking to go to a set of 215/75/15. It suggests that the standard 5.5 inch rim wouldn’t be suitable for that width of tyre. Makes sense particularly when you’ve aired down. Is this rubbish? What do you guys think?
It suggests that the standard rim 5.5 inches can run a max 195 width tyre. To safely run a 215 width tyre you’d need a 7” rim. (Apparently)
www.tyresizecalculator.com/charts/tire-w...wheel-rim-size-chart
Replied by DAGZOOK on topic New Gen Jimny Tyre size
cyberdriver wrote: 215/80R15 are within the limits for the original rim, smaller (height and width) than 235/75R15 so should be OK.
Last edit: 20 Aug 2019 05:33 by DAGZOOK.
- AlexK
20 Aug 2019 07:50 #212351
by AlexK
Replied by AlexK on topic New Gen Jimny Tyre size
Their own rim calculator doesn't agree with that table, so I think it's safe to call that just plain wrong.
The increase in tyre width is less than an inch, remember. Certainly my 215/75/15s are quite happy on my standard rims.
- Thank you received: 1928
20 Aug 2019 07:56 #212354
Replied by Lambert on topic New Gen Jimny Tyre size
Cars with low profile tyres are different to SUVs with high profile tyres. The standard fit for the gen3 is a 205 on a 5.5j rim. It is possible though difficult to find the recommended rim size for every single size of tyre from every brand as they are legally bound to provide it. As a general rule though the rim should be about 70pc the width of the tyre give or take ish.
Time to create page: 0.556 seconds
