Re:New Gen Jimny Tyre size
20 Aug 2019 15:59 #212395 by mlines
Replied by mlines on topic Re:New Gen Jimny Tyre size
For the same PSI, the area of rubber in contact with the road is the same on different sized tyres
  • iawra
20 Aug 2019 16:31 - 20 Aug 2019 16:34 #212397 by iawra
Replied by iawra on topic New Gen Jimny Tyre size
There is an interesting study from Scott Bradly about the subject:
study
Another quote from Chris Scott (Sahara overland book 2004):
"...Note that it's the diameter or height of the tyres that makes the difference in sand, and not, as many imagine the width... For the desert, you want tyres with a high aspect ratio of around 80 because this represents a taller sidewall so corresponds to added ground clearance when firm, and a longer contact area when deflated"
Last edit: 20 Aug 2019 16:34 by iawra.
  • Andy2640
20 Aug 2019 19:14 - 20 Aug 2019 19:15 #212412 by Andy2640
Replied by Andy2640 on topic Re:New Gen Jimny Tyre size
mlines wrote: For the same PSI, the area of rubber in contact with the road is the same on different sized tyres
If ive not misundersrood something here (which incidentely happens a lot) :cheer: :cheer: then im all at sea with that statement.
So lets say we have a hypithetical and silly 415/75/19 tyre at 30 PSI. And conversely we have a 215/75/15 at 30 PSI.
Are we to believe that there will be the same "measured area of rubber on road" with both examples??
SCRATCH NOGGIN TIME :blink: :blink: :blink: :blink: :blink:
Last edit: 20 Aug 2019 19:15 by Andy2640.
20 Aug 2019 19:31 #212417 by mlines
In simple terms, yes.
It took me a long time to believe it and a very long argument that was only "proved" when I went and tried it.
Leaving aside the main variable factor that different tyres have different strength sidewalls (remember Denovo run flats?).
So based on similar construction tyres and a 1,135kg Suzuki Jimny,
A 1,135kg Jimny weighs 2502 pounds, or 625 pounds per wheel.
At 23 PSI of pressure then 625/23 is 27 square inches of tread on the road surface, note that the tyre size is not mentioned at all.
To prove it, drive your car onto a piece of white paper, then mark around the tyre and calculate the square inches of contact.
The following user(s) said Thank You: Andy2640
  • Andy2640
20 Aug 2019 21:02 - 20 Aug 2019 21:12 #212421 by Andy2640
I actually kinda understand this now. The pressure of the tyre only allows for a certain surface area to make contact with the ground. A larger tyre would not depress so much on the ground because of the weight being the same on each jimny tyre. A smaller tyre would depress more, causing a greater area of rubber to be making contact with the ground.
It essentially makes the 'area of tyre' touching the ground the same, regardless of tyre size.
Its hard to get ye head around, but yes i do get that now.
Thats a real head scratcher....and ive just had a major "Aahhhaaaaa moment".
Its another matter entirely though when a larger tyre is deflated for off road driving. Even a few PSI would make the larger tyre a major advantage due to 'tyre area on ground' being HUGE.
My head hurts :pinch: :pinch: :pinch: :)
Last edit: 20 Aug 2019 21:12 by Andy2640.
21 Aug 2019 04:30 #212433 by Lambert
Replied by Lambert on topic Re:New Gen Jimny Tyre size
This is where tread design and depth come into play. Accepting that the contact patch is the same area for the same car at the same pressure my road pattern has less voids in the rubber within that area so grips tarmac very well. A mud tyre has significantly more void area within the same contact patch and is therefore unable to grip as well. Off road however I have effectively the entire contact patch resting on the surface with very little ability to find traction in a more stable lower strata. The mud tyre on the other hand has relatively more pressure per individual tread block and usually a much deeper tread to allow it to sink in to the substrate further before the entire contact area is touching, this effectively increases the surface area of the tyre allowing it to find traction. All this is before you get involved with water dispersal and self cleaning designs for the tread. It is all extremely fascinating and very clever stuff.
