Re:New Gen Jimny Tyre size
- chmnda
16 Aug 2019 02:48 #212148
by chmnda
New Gen Jimny Tyre size was created by chmnda
Hi there,
Does anyone know what's the max tyre size the new gen Jimny can go?
without lifting and still sticking with the stock rim which come with the car.
Everyone is saying 215/75r15 but that does not do much to the lift of the car, it is just a slightly wider tyre.
Anyone mind helping here?
Thanks!!
Thanks!!
- Thank you received: 1928
16 Aug 2019 04:08 #212149
Replied by Lambert on topic New Gen Jimny Tyre size
The problem seems to be that even though the arches look oversized there isn't an awful lot of room before the tyres start rubbing. There's also the gearing to consider too.
- chmnda
16 Aug 2019 05:32 #212151
by chmnda
Replied by chmnda on topic New Gen Jimny Tyre size
so the best is 215/75r15?
16 Aug 2019 05:49 #212153
I don't have a gen4 so can only go off what is being reported here but it certainly seems that way without a lift.
16 Aug 2019 08:16 #212154
by Gadget
Replied by Gadget on topic New Gen Jimny Tyre size
215/75R15 is the biggest that the stock rims will take. A couple of people in Australia have fitted 235/75R15, but those exceed the recommended limits of the rims so probably not legal or insurable in the UK.
If you want more clearance then new rims and a lift is the way to go, but then you start getting into the realms of needing to alter gearing to match.
- aage
16 Aug 2019 17:48 - 16 Aug 2019 17:49 #212178
by aage
Replied by aage on topic New Gen Jimny Tyre size
I´m still waiting for my Jimny but already bought a 235/75-15 BFG tires. Gonna install them on the standard aluminium wheels. Did talk to some guys at the tire store who said they had already used that tires on few Jimny´s and it did not rub anywhere. I´m not sure I believe them but anyway, Im gonna start by installing a 1 inch spring spacers and might do some little bit of cutting from the inside of the bumper.
If that is not enough then I'm gonna use a new ( used ) Jimny steel wheels with the original tires until I have done some proper modifications.
Last edit: 16 Aug 2019 17:49 by aage.
Time to create page: 0.478 seconds
