Recommendation for gasket sealant on king pins
29 May 2019 20:42 #209196
by Auldshug
Hi all,
Just a quick hello and a bit about my Jimny which I've inherited through my son in laws late father.
Well the Jimny is a 2000 ,13, auto. 32000 roughly on the clock been garaged for most of its life ,not been driven for 2-3 years so I'm about to embark on preparing to start it. as many of you will know it. Won't start there are many things that you need to do prior to starting I've got list of things that you need/should do ,any additional things that I need to do please let me know.
Here's what I've found to do so far
Check battery =charged
Check spark plugs and lightly oil cylinders (mystery oil) done
Oil & filter change
Drain old petrol tank and refill with fresh,
Spray some carb cleaner into carburettor .cold
Cold crank engine over to get things moving.
I'll let you know how things develop!
Oil & filter change
29 May 2019 21:10 #209197
by Scimike
Hello and Welcome .
Good luck, hope it all works.
You may find it will no go in gear which is likely to be the clutch stuck to the flywheel, can happen on stored vehicles. If so you can try keeping the pedal depressed for a few hours or start the car in gear, clutch pedal depressed, foot on brakes. This shock can free the clutch.
Mike
Mike
29 May 2019 21:43 #209199
by Auldshug
Cheers Mike it's an automatic!, I was over on Monday trying to start with its old battery no joy just no enough CCA for this jimny,so I've ordered a new,The problem is its position ,facing inside the garage and some trees over grown at one of driveway gates so couldn't even get my car in to give it a jump start.
29 May 2019 22:12 #209203
by Scimike
Ah - missed that bit, my bad.:laugh:
29 May 2019 22:40 #209205
Replied by Daniel30 on topic Newby
Welcome and good luvk
Time to create page: 0.361 seconds
