Recommendation for gasket sealant on king pins
30 May 2019 08:18 #209227 by Max Headroom
Replied by Max Headroom on topic Re:Newby
A BigJimny welcome!
I lay a classic car up for ages - I always put a shot of upper cylinder lubricant such as good old fashioned red-X into the bores through the spark plug holes before cranking it - there may be a little corrosion in there, and that would help reduce scoring.
If it's been sat a very long time the clutch may have seized on - if so, handbrake off and rock the car back and forth with it in 1st or reverse gear and it should free up. (Chock the wheels at a small distance for safety)
I'd say drain and refill the axles as well
30 May 2019 21:38 #209274 by Auldshug
Replied by Auldshug on topic Newby
Cheers for all your welcomes/ hellos
Any way did the old crank with the plugs the other coolant/brake fluid I'll do when I get Jimny home to my , done the mystery oil on top of the cylinders ,got new battery fitted tonight and it started on the third attempt with a bit of throttle.how ever idle speed 1800seems to high even after initial warm up any ideas,though drops down to 1100 in drive and reverse its as if something's stuck every now and again it drops to 1500 then back up to 1800.
31 May 2019 04:05 #209278 by Lambert
Replied by Lambert on topic Newby
The revs will stay quite high for anything upto the first mile or two of driving depending on how hard you are having to work it. Once it is properly up to temperature then it should settle down.
The following user(s) said Thank You: Auldshug
31 May 2019 10:16 #209301 by Auldshug
Oh forgot to mention I had it idling for a good half an hour up to temp.
It’s not mot/ taxed ,could only drive in and out of garage to make sure that things are free, so I’ll have to arrange for a pickup by the local garage.
  • Daniel30
31 May 2019 14:08 #209313 by Daniel30
Replied by Daniel30 on topic Newby
It might settle after you have given it a GOOD heavy right foot run as it's been sitting for a while
01 Jun 2019 09:48 - 01 Jun 2019 09:50 #209373 by kirkynut
Replied by kirkynut on topic Newby
Welcome along! It might be the idle control valve sticking. Use it a bit and see if it improves, I think it will with a bit if use.
If it doesn't, that would be where I'd start but obviously check the throttle cable is not caught up anywhere or not returning to rest. It will be fine I'm sure and my money is on the icv.
Last edit: 01 Jun 2019 09:50 by kirkynut.
Time to create page: 0.256 seconds
