Tyre tracking
30 Nov 2018 00:07 #198426 by Max Headroom
Replied by Max Headroom on topic Tyre tracking
Holy Cow!
...And I guess that's assuming some plonker hasn't had the steering wheel off and put it back on on the wrong spline :lol:
30 Nov 2018 16:55 - 30 Nov 2018 16:56 #198447 by Delux
Replied by Delux on topic Tyre tracking
We had one in our Subaru dealership today.
Customer has a Legacy diesel and usually takes it to his local small garage.
He had a small incident last winter and bounced it off a kerb.
Local garage checked it, replaced the bottom suspension arm and adjusted the tracking. Was ok for a few days then began pulling left. The garage checked and adjusted the tracking again. Then again and again. Eventually, they told him to take it to the dealer as they had tried everything they could to make it drive straight.
My colleague stuck it up in the air to do a quick visual check as someone else was using the alignment stuff...
and found the passenger rear brake caliper sticking! First time the local garage set the tracking they problably set it correctly but when the caliper started to stick and it began pulling left they tried to correct it by knocking the wheel alignment off to make the car pull right.
Quick strip and clean of the rear brakes then reset the tracking and the car is perfect!
Why is this relevant? Because Jimnys are prone to sticking slides in the front brake calipers! Perhaps something to check if your jimny starts pulling to the side, especially if you have'nt hit it off anything.
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Last edit: 30 Nov 2018 16:56 by Delux.
01 Dec 2018 09:29 - 01 Dec 2018 09:30 #198467 by Max Headroom
Weirdly the sticking sliders on mine gave me the 'apparent' symptom of warped discs rather than pulling to one side
Last edit: 01 Dec 2018 09:30 by Max Headroom.
  • Chalky the Jimny
10 Mar 2021 19:34 #233628 by Chalky the Jimny
Replied by Chalky the Jimny on topic Tyre tracking
Hi all,
I just got new tires (bfg's) and did alignment.
It now pulls to the right and the shop closed so I'll go back tomorrow.
However when they were doing the alignment, I saw they set it to the old model (gen 3) and not Gen 4 for the alignment specs, as they don't have the new specs yet (what they told me).
Will that make a difference? Are the alignment specs the same for both models?
Cheers
11 Mar 2021 10:36 #233637 by Roger Fairclough
Replied by Roger Fairclough on topic Tyre tracking
When a workshop carries out a 4 wheel check they are measuring the various dimensions that make up the suspension geometry. As the rear axle is a fixed unit - no steering components - the only measurement is wheelbase and maybe track.
On the front they will check castor angle. This is a fixed figure that can be altered but not adjusted. Tracking can be adjusted and is one of the causes of unusual tyre wear. Also remember that road camber can cause a motor to wander towards the kerb.
Roger
15 Mar 2021 12:36 #233742 by Soeley
Replied by Soeley on topic Tyre tracking
Chalky the Jimny wrote: Hi all,
Cheers
Did you get this sorted out?
Time to create page: 0.105 seconds
