Tyre tracking
- Cremator1
29 Nov 2018 18:07 #198385
by Cremator1
Replied by Cremator1 on topic Re:Tyre tracking
Hi delux no did not spot typo anyway if anyone did with a right up like u have done I would go around and sort them out lol anyway thank u so much for all your help and time did not get a chance to go to garage today but will go Saturday and update you x
- Stevie
29 Nov 2018 20:29 #198401
by Stevie
Replied by Stevie on topic Tyre tracking
I've been doing a lot with my truck lately, and tracking was on the to-do list, so just a thought when I read this topic.
The service manual states the centre-to-centre of the track rods should be 1132mm apart, so why not buy a length of aluminium extrusion from a hardware store and drill two 12mm holes, 1132mm apart, and adjust tracking until it drops over the protruding threads on the track rods. The extrusion might need a simple dog-leg bend or two, so drill after doing the bends, but as long as the c-to-c is 1132mm, it should be fine. I will take a look tomorrow to see if it is feasible.
Steve
Steve
29 Nov 2018 21:34 #198404
by Delux
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Replied by Delux on topic Tyre tracking
Stevie, thats similar to the device they use at the stock car racing. I dont mean that in a bad way! They usually use a bit of steel box section with a mark in the middle that lines up with the centreline of the car and a bit attached at right angles either end. On that bit there is a large bolt either side that is tightened against the wheel rim.
I didnt realise there was a figure quoted in the manual. The only thing to be aware of is this will only set the tracking, not the alignment of the steering wheel.
- Stevie
29 Nov 2018 22:27 #198412
by Stevie
Delux, you are correct, it will only set the tracking. My thoughts were that after setting the rear track rod for the tracking alignment, the front track rod could then be adjusted to align the steering wheel. The manual also gives 864.5 for the front track rod, but since this would be more difficult to measure and set, I guess it would just be adjusted until the steering wheel was central.
Steve
Steve
- Max Headroom
- Banned
- Thank you received: 216
29 Nov 2018 22:43 #198414
by Max Headroom
Replied by Max Headroom on topic Tyre tracking
If I'm understanding this correctly, wouldn't t you set the steering wheel into its central position and hold it there somehow (straps to door-handles gear lever etc) and then adjust the track rod ends?
29 Nov 2018 23:21 #198421
by Delux
Yes Max, but...
Adjusting the tracking is not the same thing. This method may set the tracking correctly but to accurately set up the steering wheel you need to compensate for the angle of the rear wheels. You may be able to get it pretty close but luck will have to come into it.
To set the tracking and centre the steering wheel, right first time you really need to know the alignment of the rear wheels, the combined cross toe effect. This is the advantage of 4 wheel alignment.
The given measurement in the manual may set the front wheels to the correct angle but this is assuming the rear is correct. In the real world it wont be.
In the manual I have, in 'section 3a, Wheel alignment' the manual states the front of the front wheels must toe in between 2 and 6 mm more than the rear of the front wheels. However, this works on the assumption the distance between the centre of the hub front to rear, both sides is the same, which it wont be, even when your Jimny rolled out the factory! This is the factor you are compensating for when you set the tracking at the front measuring against the rear wheels.
Do not be under the illusion when you take your Jimny to the dealer for wheel alignment they break out the manual and measure for 2-6mm. If they did there would be a lot of unhappy Jimny owners! I have been that very mechanic in a previous life! Last time I worked in a Suzuki dealer they had a very fancy Hoffmann alignment computer that had all the alignment data preinstalled. You selected the model, fitted the sensors on each wheel then it told you what to adjust and by how much!
Most modern wheel alignment equipment measures in degrees rather than millimetres. With 16" wheels, 2-6mm works out something like 10 to 30 minutes (thats what you call bits of a degree, 60 minutes make 1 degree) therefore, other than manufacturers manuals, most sources (eg.Autodata) quote wheel alignment data in degrees.
Time to create page: 0.105 seconds
