Time to change the springs again?
- 1066Boy
- Thank you received: 1939
- 1066Boy
- Thank you received: 923
- 1066Boy
- TomDK
S200KYS wrote: Hmmm, getting custom springs wound sounds complicated... I don't particularly know what specification to order, hence searching for a spring that should suit the extra weight of my Jimny...And then there's the price of getting custom springs made? The one I've sourced as a sample was £36.44 including free delivery...
I'm pleased with the trailmaster ones I have on the daily driver, and originally had the same on S200KYS too, when it first started it's transformation...
The spring I got off eBay has the right number of coils, can be cut to the right lengths I want - and without having to run spacers to top them up (as I would have to with the trailmaster +3") and would appear to be the right thickness, given the trailmaster diesel and +3" springs are wound with 13mm wire (and the ones I have fitted now, the +3" front diesel springs all round), and the one I have sourced is 14.5mm wire...?
So, I think they should suit?
I haven't said what vehicle they come off, as I think they're more suited to a heavy Jimny like mine, and may not be suitable for everyone...
I was just looking for thoughts before trying them... No-one has said they don't think they are suitable? Just suggested alternatives...
I'm in no rush, I'll give it some time to see if there's any more comments, and think about it some more myself too...
Please do chip in with any thoughts? Thanks!...
I'm quite sure you'll find the springs made of 14.5mm wire far to hard. On the TM springs, notice the difference in spring rate on the equal length springs, going from 12mm to 13mm 26 N/mm vs 40 N/mm. The 3" lift springs are very hard compared with all other springs i've tried.
