Time to change the springs again?
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
26 Sep 2017 11:07 #184516 by X8GGY
Looking at S200KYS and I think the springs have sagged again, after another 18 months use, so I've been considering my options...
We all know from countless tough-in-cheek comments that my Jimny is a little on the heavy side ;) There's an internal roll hoop, external roof tree-scraping bars to save the hardtop rear section and front soft-top section that has been retained for the odd sunny day we might get, front and rear metal ORA bumpers with winches front and rear, a big box of tools and another of spares inside the roll hoop... and a ground anchor behind my seat and a bag of strops, ropes and snatch blocks, etc, behind Alan's seat...
I've got ORA's girder-like radius arms fitted which I believe are castor-corrected for 4" lift...
I'm currently running +3" front diesel springs from a well known Jimny supplier (I won't be mentioning their name or products anymore having fallen out with them!) on the front and rear, the fronts having a pair of my spring spacers added to the tops...
So, what to fit on this latest refresh of the springs? As above, I don't want to give my hard earned to the big UK Jimny supplier... :lol:
So...
Zanfi? Bit dear, probably not weighted enough for my heavy Jimny?
trailmaster? I considered asking them, through the BigJimny store if they would supply me with 4x front diesel springs, but discovered they are the same length as the 2" but just wound thicker, see below...
The Polish company I got the roof-rack for the gold Jimny off? Again, probably not weighted enough...
Sooo... I started my research and ended up at one of TomDK's old posts -
So from that I worked out with some more googling that standard front springs are 335mm long and wound from 10mm diameter 'wire', the rears are 288mm stock length and also 10mm diameter wire
Trailmaster +2" fronts are 368mm long (33mm longer) but wound from 12mm wire
And their diesel springs are 353mm long (shorter?) but wound from 13mm wire
Mine are fitted and I can't really take them off to measure them, but I got the vernier out and they are 13mm thick wire too...
So, some more googling, and on some other Suzuki forums I discovered others using springs off other models of cars (also sold on eBay as lift springs!) which has been discussed on this fine forum before too...
And I eventually arrived at these -
So I just bought one to have a look at, which turned up this morning -
These are the correct internal and external diameter coils to match Suzuki fitment but are 442mm long (too long, but from my research others just lop a coil or two off) and wound from 14.5mm diameter wire...
So, I think, these are a good match for the extra weight my Jimny carries, and I can cut them to the correct length and not have to run spacers on the front to make up the 4" suspension lift I want to refresh...
I'm considering buying another three springs, and cutting one coil off for the fronts to make them 400mm long, and 2 coils off the backs to make them 360mm long...?
But before I do, what do you think? ;)
  • MWells
26 Sep 2017 14:18 #184519 by MWells
Replied by MWells on topic Time to change the springs again?
How about getting some made to your requirements? There are plenty of companies out there that are willing to make custom springs in small batches or one offs.
26 Sep 2017 16:09 #184527 by mlines
Used by a number of UK Jimny parts suppliers - www.coilsprings.co.uk/
Sent from my Nexus 6P using Tapatalk
  • TomDK
26 Sep 2017 17:02 - 26 Sep 2017 17:03 #184528 by TomDK
Replied by TomDK on topic Re:Time to change the springs again?
Sorry to say Dave. But that's the price of quality springs. Be it Trail Master, Old Man Emu, Tough Dog, Dobinsons etc etc..
Zanfi springs are the same price.. Hope they match the quality.
Jimnybits springs are only half the price of that and in my opinion you usually get what you pay for.
The TM springs I had didn't sag a bit. When i sold them after 2 years they were still at full length.
If your Jimny is that heavy, I'd really consider the 3" lift springs from TM. They are in reality only 2" longer than standard springs. But made of 13mm wire and fairly hard.
Sounds interesting about those springs. Do you know what they're from?
Last edit: 26 Sep 2017 17:03 by TomDK.
27 Sep 2017 08:33 #184548 by Lambert
Is there a link to where you got your new longer spring from?
  • X8GGY
  • Platinum Member
  • Platinum Member
27 Sep 2017 15:47 #184555 by X8GGY
Hmmm, getting custom springs wound sounds complicated... I don't particularly know what specification to order, hence searching for a spring that should suit the extra weight of my Jimny...And then there's the price of getting custom springs made? The one I've sourced as a sample was £36.44 including free delivery...
I'm pleased with the trailmaster ones I have on the daily driver, and originally had the same on S200KYS too, when it first started it's transformation...
The spring I got off eBay has the right number of coils, can be cut to the right lengths I want - and without having to run spacers to top them up (as I would have to with the trailmaster +3") and would appear to be the right thickness, given the trailmaster diesel and +3" springs are wound with 13mm wire (and the ones I have fitted now, the +3" front diesel springs all round), and the one I have sourced is 14.5mm wire...?
So, I think they should suit?
I haven't said what vehicle they come off, as I think they're more suited to a heavy Jimny like mine, and may not be suitable for everyone...
I was just looking for thoughts before trying them... No-one has said they don't think they are suitable? Just suggested alternatives...
I'm in no rush, I'll give it some time to see if there's any more comments, and think about it some more myself too...
Please do chip in with any thoughts? Thanks!...
Time to create page: 0.331 seconds
