Receiver hitch
04 Mar 2016 04:55 - 04 Mar 2016 04:56 #163326 by Lambert
Replied by Lambert on topic Receiver hitch
Yorkshire, England, UK. like it says on mi site profile.
So what is being said is that such things are available and are useful but are not legal under type approval.
Oh well back to the plans then.
Last edit: 04 Mar 2016 04:56 by Lambert. Reason: Predictive text
04 Mar 2016 07:39 #163329 by Busta
Replied by Busta on topic Receiver hitch
mlines wrote: You need to state which country you are asking about.
If its UK then the receiver style hitches used elsewhere in the world are not type approved. you can use them for your own off-road purposes but you cannot tow on road with them.
I'm not sure that is true. We have a factory fitted one on our range rover.
  • gilburton
04 Mar 2016 08:31 #163332 by gilburton
Replied by gilburton on topic Receiver hitch
Yes they are available for range rovers but none have been designed/type approved for a Jimny in the EU.
The manufacturer has to type approve for each model.
Probably the OP would be easier either getting a trailer or flange type towbar and/or make up some sort of rack that would bolt /clamp to the existing towbar.
Watling towbars do a clamp adapter for swan neck towballs that allows you to slot in the receiver type hitches BUT you can't use it for towing(on the road) and it costs £75+ vat so, as a flange type towbar for a Jimny can be had for around £100 new, it would be easier to go down that route and you can then bolt on what you like and still tow. (75 kg nose weight though!!!)
www.watling-towbars.co.uk/import_vehicle_towbars.html
04 Mar 2016 08:49 #163333 by mlines
Replied by mlines on topic Re:Receiver hitch
The difference is that when people talk of a receiver hitch they are thinking of the standard USA style 2" box section receiver for which an infinite selection of accessories is available. There are plugin tow hitches available for a number of UK cars (including my Range Rover) but these do not obey any "standard" as they are specific to type and are approved on type. I notice Tow Trust are bringing out a range of plugin tow bars but these are not to the receiver standard.
Looking at them, receiver hitches plug in along the axis of the pull, the tow trust ones (and my Range Rover one) is at nearly 90 degrees to the axis of the pull. I wonder if this is part of the reason .
Sent from my Nexus 6P using Tapatalk
04 Mar 2016 17:39 - 04 Mar 2016 17:46 #163349 by Busta
Replied by Busta on topic Re:Receiver hitch
mlines wrote: The difference is that when people talk of a receiver hitch they are thinking of the standard USA style 2" box section receiver for which an infinite selection of accessories is available. There are plugin tow hitches available for a number of UK cars (including my Range Rover) but these do not obey any "standard" as they are specific to type and are approved on type. I notice Tow Trust are bringing out a range of plugin tow bars but these are not to the receiver standard.
Just to clarify, our Rangerover has a USA style 2 inch horizontal jobby rather than the factory clip in thingy. Exactly the same fitment as the Reece hitch I had on a Patrol in Australia. I'll see if I can find a plate on it. It's a 2008 UK car and I'm pretty sure it had it from new.
They are a good system in terms of interchangeability but after 200,000 miles (!) of towing ours has a few shims hammered in to stop it knocking.
ETA picture:
Last edit: 04 Mar 2016 17:46 by Busta.
04 Mar 2016 18:08 - 04 Mar 2016 18:14 #163350 by mlines
Is it an imported bar? Doesnt look like a LandRover one?
www.ntta.co.uk/law/towbars/type_approval.aspx
From another tow bar site
Additionally, US 2" and 2 5/16" towballs are not Type Approved and should not be used in conjunction with Type Approved vehicles. They can however be used with non Type Approved vehicles which include all special import vehicles from Japan and America and UK commercial vehicles including all vans and pick-ups.
Last edit: 04 Mar 2016 18:14 by mlines.
Time to create page: 0.562 seconds
