Jimny won't turn over!
- mickt
17 Jan 2016 18:09 #160557
by mickt
Replied by mickt on topic Jimny won't turn over!
Although that worked it means there is a fault that is not going to go away and one day the "tap" will not work and you could be stranded. Best to plan a removal inspection clean and if all good a refit of the motor just to ascertain if it needs a new one or it was a loose connection or corroded terminals, muck or the like.
- gusthegorilla
17 Jan 2016 19:16 #160564
by gusthegorilla
Made up for it now though, mate....if you have a Jimny, you have everything
:whistle:
Replied by gusthegorilla on topic Jimny won't turn over!
BGBrit wrote: Yes Gus,, simple things first and move on to next... When I was a kid I'd use the brolly too! For walking in the rain, we had no car... :S
17 Jan 2016 21:11 - 17 Jan 2016 21:13 #160574
by Busta
Replied by Busta on topic Jimny won't turn over!
Keep it parked on a hill just in case
Last edit: 17 Jan 2016 21:13 by Busta.
The following user(s) said Thank You: BGBrit
18 Jan 2016 04:53 #160576
by kirkynut
Replied by kirkynut on topic Jimny won't turn over!
It's the solenoid getting stuck. The only way to fix it is to change the whole starter or just the solenoid.
18 Jan 2016 07:30 #160579
by BGBrit
Replied by BGBrit on topic Jimny won't turn over!
Yes, all correct, thank you....
Luckily there are lots of hills here so thats not a problem, but I'll follow Mickt and Kirkynut's advice and replace it in the spring when I have sourced one and the weather improves...
A little risky I know to wait, but hell, life's full of risks.....
BGBrit...
BGBrit...
18 Jan 2016 08:10 #160583
by Busta
It's not a risk if you're on a hill or know you can get a push to start it. Jimny's start pretty easily. I've driven a lot of miles in Australia in a car that I had to park on a hill or get a push to start (Nissan Patrol, so getting a push wasn't always easy!). Eventually had to sort the starter out when the clutch slave cylinder failed so it had to be started it in gear. Then had to drive another 700km with no clutch until I could get a new slave cylinder. Nothing is impossible!
Time to create page: 0.891 seconds
