Jimny won't turn over!
16 Jan 2016 17:46 #160489 by BGBrit
Replied by BGBrit on topic Jimny won't turn over!
Thanks Busta,
I'll try that... Four years ago my mate who has since returned to England had a Renault laguna estate it was old 1995, but worked fine until the starter motor broke down, he took it along to a local bulgarian garage where they set about putting in a new one. They did the job fine it started thereafter... Only thing was, a chassis member was blocking the starter access so they cut the chassis and removed about 250mm of it to gain access, they didn't bother to weld it back. There are many horror stories here, from stolen parts ie good brake systems taken off and replaced by rubbish.
This is why I bought a car in England and drove over here, I can't trust the mechanics here, I will do as much work myself even though I'm a novice.
BGBrit.
16 Jan 2016 21:32 #160506 by Johnniehec
Replied by Johnniehec on topic Jimny won't turn over!
Johnniehec wrote: Have you got your Jimny fixed? is there plenty fuel in it?
Mine did it last night, was very low on fuel. stopped, turned engine and lights off and took trailer off and parked it up. back into the Jim turned ignition but nothing, starter not turning. I bump started it and drove a mile back home, reversed into drive switched off and tried to re-start, but no go. fuel guage (mine works well and is generally accurate)was right at the bottom of the red. Came home tonight with a jerry can of fuel and tried to start it, still the same, not turning over, put the fuel in and tried again and it started second time! Tried it off and on a few times and it started perfectly every time, Has anyone else experienced this? I'm wondering if the engine management doesn't sense the fuel pressure it won't try to start?
Cheers,
John.
Well sorry this is a load of boll***s did it again Today, plenty fuel!!! gave the wires to the starter a wiggle and it started!!
The following user(s) said Thank You: BGBrit
17 Jan 2016 06:46 #160512 by BGBrit
Hello Johnniehec,
I'll try anything when in a hole, expect more digging. I'm going to check the all the contacts, earths too, try the easier jobs first then move on to the harder ones if not successful. Sounds like you have loose connections too on your starter.
Cheers.
BGBrit.
17 Jan 2016 17:16 #160545 by BGBrit
Little Jimny back and running fine again,, gave it a whack with a long thin length of wood with a hammer behind it, only took the one whack.
I'll keep the hammer and wood in the back in case the same problems arises later in the day.
I'm hoping this is enough as the job of removing the starter is problematic. We'll see, Thanks for the advice all....
BGGrit.
  • gusthegorilla
17 Jan 2016 17:23 #160548 by gusthegorilla
Replied by gusthegorilla on topic Jimny won't turn over!
BGBrit wrote: Little Jimny back and running fine again,, gave it a whack with a long thin length of wood with a hammer behind it, only took the one whack.
BGGrit.
When I was a kid I had a mini with exactly the same problem.... I used to keep a golf brolly in the car for just that...worked every time, Tony :whistle:
17 Jan 2016 17:49 #160553 by BGBrit
Yes Gus,, simple things first and move on to next... When I was a kid I'd use the brolly too! For walking in the rain, we had no car... :S
Time to create page: 0.219 seconds
