Spotlight wiring
- gusthegorilla
- Visitor
21 Dec 2015 03:00 #158895
by gusthegorilla
Replied by gusthegorilla on topic Spotlight wiring
Not a problem, Tony....threads are for everyone's help, not just mine :whistle: :whistle:
The wiring at my headlamps don't even have one which is red with silver bands, so you may still be right about the red being used as the trigger!!
When I'm done, I'll post a picture....the lights will either be working as they should, or there'll be a lot of water and blue lights around...time will tell :woohoo: :woohoo:
Gus
Gus
![:) :)](/media/kunena/emoticons/8.png)
- Thank you received: 923
21 Dec 2015 09:19 #158903
Replied by X8GGY on topic Spotlight wiring
Yes, that's a Vitara diagram, not a Jimny...
You need to find which of the three 'live' wires to the headlight bulb drops to negative when the headlights go to full-beam...
Dave
Dave
![;) ;)](/media/kunena/emoticons/11.png)
The following user(s) said Thank You: gusthegorilla
- skywalker65
- Premium Member
- Thank you received: 20
24 Dec 2015 22:14 #159080
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic Spotlight wiring
Gus think of the relay as 2 separate circuits
Terminal 30 on the relay is the power supply in to work your lights. Usually from the battery via a fuse.The power feed out to your lights is usually from terminal 87 on the relay.
Terminals 86 and 85 switch the relay on / off via a separate power and earth feed .... This makes terminals 30 & 87 connect or disconnect hence powering up or down your lights if that makes sense
- gusthegorilla
- Visitor
27 Dec 2015 10:28 #159182
by gusthegorilla
Nine cherries. ...haven't forgotten you on this one, Tony....just haven't had a minute to myself yet...probably tomorrow, mate ![;) ;)](/media/kunena/emoticons/11.png)
Gus
Gus
- NineCherries
- Visitor
27 Dec 2015 14:06 - 27 Dec 2015 20:32 #159195
by NineCherries
Replied by NineCherries on topic Spotlight wiring
No worries. I'm hoping to grab an hour and try and get the lightbar fitted today. I have fitted wiring for mine so fingers crossed I got the trigger wire right. I'll let you know how I get on.
Last edit: 27 Dec 2015 20:32 by NineCherries.
- gusthegorilla
- Visitor
27 Dec 2015 14:20 #159196
by gusthegorilla
Okay, mate....look forward to the result, sorry I never got chance to be the guinea pig :whistle:
Time to create page: 0.170 seconds
