Spotlight wiring
27 Dec 2015 16:47 #159209 by Jezz
Replied by Jezz on topic Spotlight wiring
The trigger wire on my 05 soft top was the red wire on the drivers side headlight.
It's been fettled just a tad.
  • NineCherries
  • Visitor
  • Visitor
27 Dec 2015 17:30 #159216 by NineCherries
Replied by NineCherries on topic Spotlight wiring
Yip. It's the red wire. I tapped into the wire at the steering cowl so the joint was inside and dry. Oooft I like light bars.
28 Dec 2015 22:32 #159265 by furo
Replied by furo on topic Spotlight wiring
Great thread, thanks guys. I also got a lightbar for Christmas and I've attached it physically but need to get my head around the wiring and this is really useful. I am planning on just wiring it up with the main beam, but I've never done anything like this before!
28 Dec 2015 23:18 #159271 by furo
How common is it to simply wire up auxiliary lights to their own switch, separate to main beam? It seems that would be a lot more straightforward to set up, although not as convenient (although it could always be changed later). Is it worthwhile doing it that way, or is it much better to have it connected to main beam?
  • NineCherries
  • Visitor
  • Visitor
28 Dec 2015 23:48 #159273 by NineCherries
furo wrote: How common is it to simply wire up auxiliary lights to their own switch, separate to main beam? It seems that would be a lot more straightforward to set up, although not as convenient (although it could always be changed later). Is it worthwhile doing it that way, or is it much better to have it connected to main beam?
I suppose it depends what your requirements are. I wanted better light on road (more so when i'm on unlit back roads) so i have it triggered from the highbeam circuit, but i did include a switch so i have the option to not use the lightbar
having it on a separate switch would be fine if you are using it, for example, only off road. I wouldnt be able to drop out of highbeam and find the switch to avoid blinding any on coming drivers i meet.
PS Gus - ill get pics posted at some point soon of my completed install
30 Dec 2015 20:50 #159371 by furo
Thanks NineCherries, that's what I thought.
Time to create page: 0.154 seconds
