Spotlight wiring
- gusthegorilla
- Visitor
02 Jan 2016 15:22 #159536
by gusthegorilla
Hi, Jezz...
After a week of nothing but work, I'm finally gonna get back to this.... :whistle:
My 2004 soft top doesn't have a red wire at driver's side headlamp....can you possibly tell me which bulb terminal your red wire went to please.....when looking at the bulb from the rear, is it left, top or right?
Thank you,
Gus
Replied by gusthegorilla on topic Spotlight wiring
Jezz wrote: The trigger wire on my 05 soft top was the red wire on the drivers side headlight.
Hi, Jezz...
Thank you,
Gus
![;) ;)](/media/kunena/emoticons/11.png)
02 Jan 2016 17:27 #159544
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Spotlight wiring
Hi Gus,
I'm pretty sure it was the right hand terminal as you look at the rear of the lamp, But i'll check for you tomorrow when i go down my lock up where the jim jam is. Or if you have a test meter, pull the plug off the lamp, put the jimny on full beam. neg side of the meter to earth positive side to the plug, Two terminals will be +12 volt one should be 0 volt, flick back to dipped and it should change to +12 volt, That will be the trigger negative for your relay.
Hope that helps Jez.
- gusthegorilla
- Visitor
02 Jan 2016 19:07 #159553
by gusthegorilla
Cheers, Jezz....
That does seem to make sense when you put it like that....I'll try it tomorrow too when I'm also in the man-cave :whistle:
Thanks a lot mate, I'll let ya know....![;) ;)](/media/kunena/emoticons/11.png)
Gus
Gus
![:) :)](/media/kunena/emoticons/8.png)
03 Jan 2016 13:42 #159582
by Jezz
Hi Gus,
Yes it's the right hand terminal as you look at the rear of the lamp.
- gusthegorilla
- Visitor
03 Jan 2016 15:17 #159596
by gusthegorilla
- Visitor
03 Jan 2016 15:22 #159599
Replied by Daniel30 on topic Spotlight wiring
Very nice Gus looking smart
Time to create page: 0.143 seconds
