M13A Wokshop Manual
- Basketcase
06 Feb 2015 18:21 #137085
by Basketcase
Replied by Basketcase on topic Re:M13A Wokshop Manual
I asked one of the advisors at work(Suzuki dealer) to print me off a service schedule for my 07 reg and that said at 64k to change timing belt but it's a timing chain on the m13 engine, if you look at the engine there's no plastic removable belt cover on the end of the engine
06 Feb 2015 18:40 #137090
by BGBrit
Replied by BGBrit on topic Re:M13A Wokshop Manual
Yes! Basketcase,,, I will check all this, I'm fairly sure its a chain and not a belt, just my hand book says belt,,,, strange to say belt when they are chains, ,, I take it then I should change the Cam Chain at 64k on a M13A engine as a precaution, would your service guy recommend that? Maybe they stretch over time and slip. Some say the chain should last the time of an engine, if regular oil and filters are changed..
Cheers
Tony..
Cheers
Tony..
- Johnniehec
- Thank you received: 56
07 Feb 2015 00:06 #137123
by Johnniehec
Replied by Johnniehec on topic Re:M13A Wokshop Manual
Hi BGBrit, the M13A is definitely a chain and no you don't need to change the chain ever.
Cheers,
John.
Cheers,
John.
07 Feb 2015 09:37 #137128
by BGBrit
Thanks for that confirmation Johniehec,,, Just one job less to do, as long as regular oil changes are undertaken all should be fine.
Thanks again
Tony (BGBrit)
Thanks again
Tony (BGBrit)
- Basketcase
07 Feb 2015 10:32 #137135
by Basketcase
On the Suzuki service schedules there's no time to change the chain of it starts to get a little noisy the. I'd probably change it but until then just keep doing oil and filter every 9000 miles and diff oil every 2 years you'll be fine
07 Feb 2015 12:46 #137140
by BGBrit
Sound advice Basketcase,,,, I intend to keep this jimny going for many years, till it drops, I doubt I'll do more 3000k per year so, the engine should/will last well given I'll do the recommended oil changes, for me the main prob is rust, its a little rusty now in places being a 2009 model with 34,000k on the clock therefore I'll be doing a lot of wire brushing sealing etc to give it longevity ... Not sure which we die first me or it, becoming 61 a week ago, although I do stay well oiled too (Woods Dark Rum) so, I'm very preserved...
Tony (BGBrit)
Tony (BGBrit)
Time to create page: 0.478 seconds
