More flex without lift. Ideas?
25 Mar 2014 23:33 #110102
by Busta
Replied by Busta on topic More flex without lift. Ideas?
The bushes on the axle end move quite a lot; I was looking at them today and the twisting force is quite apparent. But Tom's right, rose joints on the chassis end of the radius arms would make little difference. It's hard to spot any movement in them at all.
26 Mar 2014 12:22 #110123
by Busta
Rose joints are generally a bad idea on anything that gets muddy. Johnnie joints are better but expensive, but to be honest the standard bushes are very flexible and work in a manner that no metal joint could; Where the radius arms join the axle the twisting force is actually pulling the bushes off-centre. Rose joints would bind up restrict this movement massively. Castor corrected bushes must also be less flexible than standard bushes (another issue with lift kits!). In this respect, I don't think the standard bushes can really be improved upon without a complete suspension re-design.
The panhard rod setup isn't the best, but installing a Defender style A frame would mean re-locating the fuel tank which is a big job. I think I'm getting more flex one way than the other on the rear, which may be down to the panhard. Something to look into when I get another chance to play...
26 Mar 2014 12:29 #110126
by Rhinoman
They can be fitted with rubber boots and usually you use a spacer either side of the rose joint to allow it to twist. The standard rubbers usually are very good, personally I'm not a fan of poly-bushes as I find they don't flex as well.
Replied by Rhinoman on topic More flex without lift. Ideas?
Busta wrote: Rose joints are generally a bad idea on anything that gets muddy.
26 Mar 2014 13:00 #110130
by Busta
Rhinoman; They can but it's never going to be as mud proof as a rubber bush! Anyway, it's not the twisting movement that's important; If you look at the bush when the axle is flexing, the bolt hole that is normally in the centre of the bush will be either pushed upwards or downwards (either front bush up, rear bush down or vice-versa). The bolt is pushed off-centre. If you can picture how the axle is trying to rotate relative to the radius arm you should be able to picture it in your head. A rose joint simply couldn't provide this movement.
Here's a quick sketch to show the movement I'm talking about:
26 Mar 2014 13:09 - 26 Mar 2014 13:25 #110133
by Busta
I'm not seeing my last post for some reason?
ETA I can see it now!
Last edit: 26 Mar 2014 13:25 by Busta.
26 Mar 2014 21:17 #110193
by Rhinoman
I'll have to have another look underneath but I'm sure that the reason for having the two bushes is to limit the rotation of the front axle. Ideally you wouldn't want any rotational movement there but you have to isolate the chassis from the vibration from the axles. I can understand that there will be some movement, after all the axle moves in an arc and the panhard rod doesn't, its all a compromise.
Time to create page: 0.222 seconds
