More flex without lift. Ideas?
  • Dave cc
25 Mar 2014 15:36 #110030 by Dave cc
Replied by Dave cc on topic More flex without lift. Ideas?
gipcyan bill wrote: Anyway
If you do find longer softer springs please share
www.dfaulknersprings.com/index.htm
Speak to these guys they wind springs for many people who then sell them on in lift kits they can pretty much wind anything you want
25 Mar 2014 17:01 #110034 by rusty spanner
Here my 2p worth lol cut the eye off your radius arms and fit rose joints to them that help as will movement than a bush then fit longer shocks +2 or some thin
  • TomDK
25 Mar 2014 17:50 #110035 by TomDK
Replied by TomDK on topic More flex without lift. Ideas?
rusty spanner wrote: Here my 2p worth lol cut the eye off your radius arms and fit rose joints to them that help as will movement than a bush then fit longer shocks +2 or some thin
Makes no difference as the bushes on the axle end binds before the rose joints will have any effect.
25 Mar 2014 18:41 #110043 by Busta
I had a bit of a play this afternoon, dislocated some springs and found some stuff out but didn't look into it too much. I'll have another look at it later this week and take some measurements, see what is restricting movement etc. and post my findings here.
25 Mar 2014 22:22 #110085 by Rhinoman
Busta wrote: I appreciate they want to limit roll, dive and squat on road but it's those characteristics that translate to better suspension articulation offroad! To me that suggests that the kits are built more for looks than any improvement in ability. If the spring doesn't allow full travel you may as well fit a standard spring with spring spacers.
When you start using them for more severe off-road use then you can end up at some more extreme angles which puts more weight on the springs; along with the higher C of G, that often means that you will be using more suspension travel than a stock system allows.
25 Mar 2014 22:25 #110087 by Rhinoman
TomDK wrote: Makes no difference as the bushes on the axle end binds before the rose joints will have any effect.
I'll have to think about that when its not so late but surely the bushes on the axle end are only there to remove vibration, they should hold the axle at a fixed angle relative to the arm.
Time to create page: 0.219 seconds
