roll cage inspiration
  • steffan
08 Oct 2013 20:35 #85533 by steffan
Replied by steffan on topic roll cage inspiration
Kirkynut can u send me the dimensions of them front bars you have on yours I have ordered a main hoop from p n p to make a copy of for the back and like the style of your front end
  • idiotmobil
08 Oct 2013 20:57 #85538 by idiotmobil
Replied by idiotmobil on topic roll cage inspiration
I got a mate with a sheet metal shop and they also have a business making gt40s called southern gt so a welth of knowledge at my disposal
08 Oct 2013 21:03 - 08 Oct 2013 21:05 #85539 by kirkynut
Replied by kirkynut on topic roll cage inspiration
steffan wrote: Kirkynut can u send me the dimensions of them front bars you have on yours I have ordered a main hoop from p n p to make a copy of for the back and like the style of your front end
I'm not too sure which bits you mean Steffan. Do you mean the bar across the windscreen or are you referring to the bumper?
I didn't make it so have no drawings etc.
I'm not too sure my efforts with a tape measure will be meaningful to you to be honest.
Be aware that I decided to have my screen bar lower down. This aids with visibility but means it has to be removed to open the bonnet properly.
Last edit: 08 Oct 2013 21:05 by kirkynut.
  • steffan
08 Oct 2013 21:03 #85540 by steffan
Not saying i no it all because am far from it just throwing in my two penith
  • steffan
08 Oct 2013 21:08 #85542 by steffan
i ment the two that run up and over the doors i will be able to fathom out the other bits its the angles that are most important don't worry if you can't i will just spend a few hours with the angel finder i have at my deposal
08 Oct 2013 21:10 #85544 by kirkynut
idiotmobil wrote: good topic ive just found some one just up the road from me to bend some pipe for my cage £7 a bend so shouldnt cost me much as the pipes coming free from my mate ill be notching and welding it are the cages fabbed up and then lifted in to place is there any thing wrong with bolting it to rockslidders and bumpers so it can be removed
Mine is bolted to my rock sliders so can be removed and is in sections so damaged parts can be replaced easier. Not that I've damaged it.
It's fabbed to be as such. My rocksliders are welded to the chassis on big spreader plates.
Time to create page: 0.635 seconds
