roll cage inspiration
  • TomDK
08 Oct 2013 21:32 #85551 by TomDK
Replied by TomDK on topic roll cage inspiration
steffan wrote:
idiotmobil wrote: good topic ive just found some one just up the road from me to bend some pipe for my cage £7 a bend so shouldnt cost me much as the pipes coming free from my mate ill be notching and welding it are the cages fabbed up and then lifted in to place is there any thing wrong with bolting it to rockslidders and bumpers so it can be removed
Make sure you use decent pipe I first planed on using scaffold poles but then decided agenst it as it's not to fia regulations were I believe that steam tube aka blue band is were CDS is expensive and not as easy to get hold of
Just remember that none of these external rollcages provide any real protection for the driver. They are all meant to protect the body and nothing more. If you want real protection you'll need some diagonal tubing in the main hoop right behind the front seats.
  • idiotmobil
08 Oct 2013 21:39 #85553 by idiotmobil
Replied by idiotmobil on topic roll cage inspiration
internal cage being planed at the moment but have had a rethink about joining the two
  • steffan
08 Oct 2013 21:46 #85555 by steffan
Replied by steffan on topic roll cage inspiration
i no what you mean but 50mm tubing is slightly over kill for a jimny as that's what thay use on land rovers which are alot heavier than jimnys a cross brace is always best tho
  • gmogger
08 Oct 2013 23:47 - 08 Oct 2013 23:51 #85563 by gmogger
Replied by gmogger on topic roll cage inspiration
No amount of OTT tube will make up for a poor design. triangulating the cage is what gives it its strength.
45mmx2.6mm cds exceeds the 350nm yeild strength for the msa regs, and would be more than strong enough for a jimny.
Last edit: 08 Oct 2013 23:51 by gmogger.
  • steffan
09 Oct 2013 05:28 #85564 by steffan
So my over kill of 50mm tube with a wall thickness of 3.2mm will be plenty strong enough
  • Dorfl
09 Oct 2013 08:10 #85570 by Dorfl
Replied by Dorfl on topic roll cage inspiration
Phone photo but anyway
[IMG
Time to create page: 0.329 seconds
