Front Brake Problems
  • Rodden87
26 Sep 2013 13:35 #84466 by Rodden87
Replied by Rodden87 on topic Front Brake Problems
In my experience if the hubs are buggered you would notice wobble all the time not just under braking. If the wobble goes when disc and pads changed then it's says to me its the disc's!
The first thing I would look for is the caliper not resetting correctly. This can be caused by a few things. Bad piston or slider on the caliper.
A problem with a brake line being obstructed, fluid will pass obstruction easily when under pressure (applying brake peddle) but when under less pressure (when fluid is returning to master cylinder) the flow may be restricted not allowing or slowing the reset of the caliper causing over heating.
Hope that makes sense
  • helijohn
26 Sep 2013 17:07 #84486 by helijohn
Replied by helijohn on topic Front Brake Problems
Rodden87 wrote: the flow may be restricted not allowing or slowing the reset of the caliper causing over heating.
That's why I think overheating would have been a symptom and a clue. On mine the front brakes seem to be doing more than their fair share of the work and apart from the balance valve we can't find why. I can imagine lots of heavy braking and a more serious situation like mine leading to front brake overheating. It's the fact that both have gone that has to be the clue surely. Thing is, you'd notice the stink!! :whistle:
  • DaveJ
26 Sep 2013 23:28 #84521 by DaveJ
Replied by DaveJ on topic Front Brake Problems
Thank you one and all.
All comments will be offered to the Suzi garage and discussed. :)
Time to create page: 0.088 seconds
