Front Brake Problems
  • DaveJ
26 Sep 2013 11:25 #84427 by DaveJ
Front Brake Problems was created by DaveJ
Hi Folks. New to the site and new to forums so please forgive any etiquette foul-ups. I am in need of some help.
I have a 2000 Jimny 73000 approx, bog standard, looks like shes never been seriously off-road. 8 months ago i needed to change the discs and pads so bought some cheapies from local factor and fitted them. All ok for a couple of thousand miles then discs distorted. This time, feeling rich I took her to local Suzi dealer and had some pucker ones fitted. Coupla 1000 miles later same thing, distorted discs. Discs and pads replaced under warrantee and fault thought to be calipers not returning correctly so new calipers. All well until a few 1000 miles later and the same thing happens again.
She's in the garage at the moment and they are saying that they think it is distorted hubs. I have asked about faulty master cylinder but they reckon that's fine and they have never had to replace one ever!
I am thinking that If the Hubs have cooked and distorted would the problem not have been immediately evident the last time the discs and pads were replaced? Would the wheels also not wobble due to the hubs distortion? Why would both hubs have distorted simultaneously? Why does it take 2 -4,000 miles before the problem restarts?
Any and all comments/suggestions welcomed!
  • adamatdraycott
26 Sep 2013 11:34 #84428 by adamatdraycott
Replied by adamatdraycott on topic Front Brake Problems
Hi and welcome,
I assume the way you know the discs are warped is pulsation through the brake and steering wobble under braking?
Not just a steering wheel wobble while driving?
  • jonesyba420
26 Sep 2013 11:46 #84432 by jonesyba420
Replied by jonesyba420 on topic Front Brake Problems
Hi there, are you positive that suzuki fitted decent disks and pads?! And not just unipart ones or some other aftermarket brand.My girlfriend whos a mechanic cant think of any reason why both hubs would be buggered other than from a hard impact to both wheels?
Ive probably been no help bit of a random fault as youve basicaly replaced the usuall suspects,
  • DaveJ
26 Sep 2013 12:00 #84438 by DaveJ
Replied by DaveJ on topic Front Brake Problems
Definitely warped discs on all occasions. Vibrations thru the pedal and only under braking and confirmed after removal!
  • markyp2000
26 Sep 2013 12:59 #84454 by markyp2000
Replied by markyp2000 on topic Front Brake Problems
Are the hubs clean of all rust etc
  • helijohn
26 Sep 2013 13:26 #84463 by helijohn
Replied by helijohn on topic Front Brake Problems
I am like everyone else over this, it seems to be a puzzler. I can only think of overheating on the discs, yes both but it has to be a long shot. Have you had any cooking smell from front underneath at all??
If the bearings were running out of true maybe the disc would be forced over. Another long shot.
