Castor correction
- reaper
07 Mar 2013 19:35 #64880
by reaper
Replied by reaper on topic Castor correction
Yes thats right mate ,leaving the insert out gives the bush enough flex to pop into the arm then just push the cores in.
You dont even need a press a vice will do
- RichiesJimny
07 Mar 2013 19:47 #64881
by RichiesJimny
Replied by RichiesJimny on topic Castor correction
So you can adjust the inserts when you refit the arm. The problem with the bushes I had is its the bush that's offset not the insert. Are the super pro's ok for a 3 inch lift or do I need radius arms really.
- reaper
07 Mar 2013 19:53 #64885
by reaper
Bushes are ment for 2" but will help with 3" , and arms are 4" lol
I think jimnybits does 3" arms and sure ora make whatever you want
- gus2000
07 Mar 2013 20:35 #64903
by gus2000
Replied by gus2000 on topic Castor correction
Hello, for here the castor correction is "something savage"
Jimny with Lift 2 1/2â€
In this case (test): 8º :dry: Excessive :dry:
Here 3º50'
Drilling
Finish....
“Gutty†solution, no drill, no weld
"El piñal", from Chile proposes for further correction
More info bigjimny.com/index.php/forum/22-espaafa-ol/48687
Gustavo
Here 3º50'
Finish....
Gustavo
- reaper
07 Mar 2013 20:37 - 07 Mar 2013 20:41 #64904
by reaper
If you have the money arms are the better way to go as mysticrich says
Last edit: 07 Mar 2013 20:41 by reaper.
- reaper
07 Mar 2013 20:40 - 07 Mar 2013 20:44 #64905
by reaper
Do not do this it will all end badly
Infact i wouldnt recomend any of the ways posted as they all drop the arm at the front reducing ground clearance , real corected arms doot sit any lower than stock
This is crazy have you never heard of M.E.D ( minimum edge distance)gus2000 wrote: Hello, for here the castor correction is "something savage"
Here 3º50'Drilling
Finish....
Gustavo
Last edit: 07 Mar 2013 20:44 by reaper.
Time to create page: 0.110 seconds
