Castor correction
  • RichiesJimny
07 Mar 2013 19:02 #64870 by RichiesJimny
Castor correction was created by RichiesJimny
Having tried and failed to fit the jimny bits economy castor correction bushes (the ones where you only change the front bushes) I'm looking at a full set of castor correction bushes or maybe some rhinoray castor corrected arms. Does anyone on here use rhinorays arms as they do look good value at £240 including new bushes and do they work with a 3inch lift.
  • reaper
07 Mar 2013 19:04 #64871 by reaper
Replied by reaper on topic Castor correction
What problem are you having fitting them ?
  • RichiesJimny
07 Mar 2013 19:06 #64872 by RichiesJimny
Replied by RichiesJimny on topic Castor correction
I've just checked Rays site they are advertised as heat treated not castor corrected :blush:
  • RichiesJimny
07 Mar 2013 19:12 #64873 by RichiesJimny
reaper wrote: What problem are you having fitting them ?
They are the cheap bushes with no metal ring, when we pressed them in the angle wasn't quite right so the bolts won't go in when we tried pressing them out and they fell to bits.
I don't know if I should buy a set of 4 bushes or get some corrected arms with normal bushes.
  • reaper
07 Mar 2013 19:21 #64875 by reaper
Bugger thats not good
The ora arms are good but depends if you need them that heavy duty
If going for bushes in stock arms its worth spending a bit more on the super-pro ones
  • RichiesJimny
07 Mar 2013 19:30 #64878 by RichiesJimny
With the super pro's do you press the bush in and then press in the steel insert. Am I right in thinking that its the steel insert that's offset not the bush.
Time to create page: 0.108 seconds
