rear uper shock bolts.
  • Smoggy
10 Jul 2012 18:42 #43896 by Smoggy
Replied by Smoggy on topic Re: rear uper shock bolts.
nicho wrote: ooo thanks i was doing it from under the car.im i right in thinking wd40 aint a penetrating fluid.might be able to get some heat on it inside wheel arch then.
I read in a recent back to back magazine test that 'plusgas' is the most effective penetrating fluid. Mind you it didn't do much good trying to get off my pitman arm :ohmy:
  • nicho
10 Jul 2012 19:14 #43898 by nicho
Replied by nicho on topic Re: rear uper shock bolts.
martin do you do the upper shock bolts as well as the lowers.
  • supergaz
10 Jul 2012 21:46 #43923 by supergaz
Replied by supergaz on topic Re: rear uper shock bolts.
You want a bodylift nicho, I can get my cordless impact gun onto mine ;-)
  • myers647
10 Jul 2012 21:54 #43924 by myers647
Replied by myers647 on topic Re: rear uper shock bolts.
Just get some heat on it, just be careful. I did mine that way with a small blow torch well Steve did. It will come straight off mate. The bolt is facing the opposite way to the fuel tank
At least if it does set on fire you know you have a fuel leak lol :silly: :silly:
  • nicho
10 Jul 2012 22:30 #43927 by nicho
ta lads guna have another do tomorow with a big bar if i can get 1.impact gun is on my list of things that would be handy.hope i get it done tomorow.
11 Jul 2012 06:49 #43930 by mlines
Replied by mlines on topic Re: rear uper shock bolts.
Yes, the rear shock bolt kit contains both the upper and lower bolts.
Time to create page: 0.195 seconds
