rear uper shock bolts.
  • nicho
09 Jul 2012 20:28 #43841 by nicho
rear uper shock bolts. was created by nicho
help .rear uper shock bolts well tight n wot the hell do you use in such a tight space to undo em.thanks id be stuck if it wasnt for big jimny.
09 Jul 2012 20:45 - 09 Jul 2012 20:51 #43844 by dirtydogz
Jack-up the back of the jimny take off the wheel, then undo the bolt from inside the wheel arch you can see it better from there.. ;)
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 09 Jul 2012 20:51 by dirtydogz.
The following user(s) said Thank You: nicho
09 Jul 2012 21:24 #43849 by mlines
Replied by mlines on topic Re: rear uper shock bolts.
And spray them every few hours for a couple of days before hand with penetrating oil. Also make sure you have a proper fitting spanner, ring spanners with "star" pattern heads with turn the edges off the nut.
  • nicho
09 Jul 2012 21:55 #43853 by nicho
Replied by nicho on topic Re: rear uper shock bolts.
ooo thanks i was doing it from under the car.im i right in thinking wd40 aint a penetrating fluid.might be able to get some heat on it inside wheel arch then.
10 Jul 2012 12:14 #43863 by Johnniehec
nicho wrote: ooo thanks i was doing it from under the car.im i right in thinking wd40 aint a penetrating fluid.might be able to get some heat on it inside wheel arch then.
I wouldn't go anywhere near there with a naked flame, it's mighty close to the fuel tank.
John.
  • nicho
10 Jul 2012 18:30 #43895 by nicho
yah saw that when i got back under the car ta,had wheel off n still cant undo it,its such a tight space,how much u recon ta get a mobile machanic ta put shocks on.
