rear uper shock bolts.
- JonathonMarshall
18 Jul 2012 21:48 #44509
by JonathonMarshall
Replied by JonathonMarshall on topic Re: rear uper shock bolts.
Are you still struggling with this? I bought the bolt set from Martin and used a nut extractor on that drivers side one with a big bar, it chewed it a bit but came straight out. Had been dowsing them all for about 10 days with WD.
- nicho
19 Jul 2012 17:54 #44544
by nicho
Replied by nicho on topic Re: rear uper shock bolts.
yep still not got them out yet going to have another go eather tomorow or sat if it aint raining again.got a big bar to try with,i also have some locking wheel nut removers that might fit so might end up using them to.
- Paul4x4
19 Jul 2012 18:28 #44549
by Paul4x4
Replied by Paul4x4 on topic Re: rear uper shock bolts.
I installed my lift kit today, and those upper bolts were stuck on really tight on my truck too, but it only took a basic ratchet spanner and some MUSCLE to crack them loose. No spraying WD40, and no special equipment. Just laying on my back under the truck using my two hands, no problem! :laugh:
- Gromit
19 Jul 2012 18:39 #44551
by Gromit
Replied by Gromit on topic Re: rear uper shock bolts.
When I did mine the inner metal sleeves had welded themselves to the bolts so used an anglegrinder to cut the bolt heads off and then spread the socket to get them out, b*stard of a job !!
Put plenty of waterproof or copper grease on the new ones !!
- nicho
20 Jul 2012 20:55 - 20 Jul 2012 20:55 #44625
by nicho
how the hell you get two hands under there, guna do it tomorow, i am going to do it.i think.seems a common problem.
Last edit: 20 Jul 2012 20:55 by nicho.
- nicho
20 Jul 2012 21:59 - 20 Jul 2012 22:13 #44628
by nicho
think i have been a right numpty, when trying ive tried to undo the bolt, n then tried to undo the nut,are the nuts fixed to the bracket.well had a spanner at the back with socket on the front.o well i have learnt summet.
Last edit: 20 Jul 2012 22:13 by nicho.
