SJ Modified front axle
- Smoggy
11 May 2012 20:54 #40008
by Smoggy
SJ Modified front axle was created by Smoggy
I've submitted some photos of my recently purchased front axle. I would be grateful for your comments. I got the unit from Gazwell and it was removed from his competition trayback Jimny. The diff is from a Jimny with ARB locker installed and diff breather as you can see in the photo. It is welded to an SJ axle with SJ shafts and hubs (the ARB side gears have been changed to fit the splines from the SJ chromoly 4340 shafts) with spring mounts and other appendages welded on to fit the Jimny.
What I don't understand is how the 4WD is selected without the use of vacuum system or manual locking hubs.
Thanks in advance guys.
- vitara_mad
11 May 2012 21:00 #40009
by vitara_mad
Replied by vitara_mad on topic Re: SJ Modified front axle
its got fixed hubs so they are locked all the time
- Smoggy
11 May 2012 21:07 #40011
by Smoggy
Replied by Smoggy on topic Re: SJ Modified front axle
Excuse my stupidity Rich but I thought that the Jimny 4WD is only supposed to be a part time system, am I therefore not going to be able to drop into 2WD using my selector from the rocklobster?
- reaper
11 May 2012 21:21 #40014
by reaper
Replied by reaper on topic Re: SJ Modified front axle
That will dissengae the drive but the hubs will still be locked so diffs props etc will still be spinning
- vitara_mad
11 May 2012 21:22 #40015
by vitara_mad
yes you still have 2wd as when you select 2wd on transfer box theres no drive to the front output on the transfer box
the only thing with fixed hubs is even in 2wd when driving the wheels are still turning the front shafts,diff & front prop but theres no drive to them so that no problem
some sj's & vits come fitted with fixed hubs as standard so no need to worry & theres nothing to go wrong with fixed hubs
the only downside is if you break a front shaft or cv you cant disengage front hubs but you can just unbolt the fixed hub to drive home
- Smoggy
11 May 2012 21:24 #40016
by Smoggy
I dont get it cos my jimny will now have sj hubs, sj transfer box and sj props and the sj had selectable 2wd/4wd? What am I not understanding guys.
Time to create page: 0.107 seconds
