Fitting a Steering damper kit
- darthloachie
11 May 2012 12:10 #39959
by darthloachie
grab a hold of the sterring arms and give them a shake - ours rattled :whistle: replaced all four
Replied by darthloachie on topic Re: Fitting a Steering damper kit
Halford wrote:
Might follow dirtydogz's thinking and try sticking on some new tie rod ends
what do you do to check if they're dodgy
- Carrow
11 May 2012 19:47 #40000
by Carrow
Replied by Carrow on topic Re: Fitting a Steering damper kit
Cheers Bluejimny, piccy helps a lot. I will get on and fit it, I have checked the tie rod ends, dirtydogz, all seem ok, but they were my thinking also, especially that I have done 54,600 miles, but my zooki has just past its MOT with flying colours.
I will fit the damper kit and report back. Thanks
- nicho
11 May 2012 21:07 #40010
by nicho
Replied by nicho on topic Re: Fitting a Steering damper kit
whats the yellow one
- Carrow
13 May 2012 11:28 #40118
by Carrow
Hi,
Quick report back, I have fitted the jimny bits steering damper kit, and I have to say, why don't jimny's come with these things as standard, WOW!! :woohoo: steering in really smooth, no more wobbles. On ther motorway at 65 MPH, yes not a typo, 65MPH, the drive was smooth.
Well worth the investment.
09 Nov 2018 08:40 #197518
by Lomax
Replied by Lomax on topic Fitting a Steering damper kit
Morning,
Just a quick question. When installing with your wheels straight. How far should the piston be in the shock when installing?
Cheers
Cheers
- Thank you received: 1957
09 Nov 2018 09:27 #197519
Replied by Lambert on topic Fitting a Steering damper kit
If the wheels are straight then half way in the stroke of the damper so you have equal travel in each direction.
Time to create page: 0.221 seconds
