Leaking coolant and engine removal?!
  • bwms
17 Mar 2012 11:03 #35709 by bwms
Hi all,
I used to be a member here but account seems to be lost, hence looks like my first post.
I hope someone will be able to help before I consign my Jimny to the bin.
I have an 2002 O2 model with 36K on the clock. 6 months ago she started leaking water. Other than overheating when I first found the problem, filling the radiator up after every other tank, kept her sweet. I was determined to sort the problem though. After checking and tidying up some hoses, I found the source seemed to be coming from behind the water pump and below the intake manifold.
I gave up for a while. Few weekends ago I tried again, realising the intake manifold would have to come off in order to get closer. What a total pain!
The manifold insn't totally removed but moved away enough to see I now need to dismantle even more stuff.
I'm now at the stage of removing the water pump. I have a load of manuals online but none seem to help much.
I hope someone will take the time to advise, I'd be very grateful.
- how do I get the crankshaft pully retaining bolt out?
- the metal cylinder behind the water pump (that inserts into the block and has three hoses coming off it) seems to be the source of my leak. If I can get to it, what are the chances of there being something I can do to seal it?
I've included a few photos if it helps.
Thanks BigJimny
Aidan
  • bwms
17 Mar 2012 11:11 #35713 by bwms
Replied by bwms on topic Re: Leaking coolant and engine removal?!
I seem to be having problems with the pics, I'll try again later.
  • bwms
17 Mar 2012 14:49 #35720 by bwms
[attachment:1]leak 1.jpg[/attachment]
  • darthloachie
17 Mar 2012 15:17 #35722 by darthloachie
Replied by darthloachie on topic Re: Leaking coolant and engine removal?!
either upload your pics to photobucket or similar and copy/paste the image link
or reduce the size of the image to about 2000 x 1600 as a jpeg
  • renard38
17 Mar 2012 17:25 #35732 by renard38
Replied by renard38 on topic Re: Leaking coolant and engine removal?!
hi,
i delete the other topic ;)
  • Blakey
17 Mar 2012 19:41 #35748 by Blakey
Replied by Blakey on topic Re: Leaking coolant and engine removal?!
What engine is it? I recently did the cambelt and water pump on my SOHC and to get the cranks shaft pulley off you undo the small 8mm bolts surounding the large bolt on the pulley and then it just prises off.
Time to create page: 0.101 seconds
