Looking for my first Jimny!
- Sam_
- Visitor
18 Feb 2012 23:15 #33733
by Sam_
Looking for my first Jimny! was created by Sam_
Hello all,
My name is Sam and I live in west sussex and am just about to try selling my car so I can buy a Jimny.
Wanted one for quite a while now ever since driving one in thailand!
If anyone has any buying advise or could point me in the direction of some where on this forum? then that would be great!
Also if anyone wants to take my clio as a p/x towards their jimny then just let me know and i'll provide more details.
Thanks
Sam.
Thanks
Sam.
19 Feb 2012 09:22 #33746
by facade
Replied by facade on topic Re: Looking for my first Jimny!
There are a couple of threads on here, but basically you are looking for:
1) rust. In the boot where the tools live, under the rear seats where the seatbelts bolt down, behind and under the headlights. The ends of the front axle, the ball shaped housings should not be seriously rusty.
2) Head gasket gone. Make sure the engine is stone cold, undo radiator cap (not the yellow cap on the plastic bottle) if you hear a hiss, or the water is low in the radiator (should be right up to the cap) likely head gasket going.
3) oil leaks, there shouldn't be any anywhere.
4) starship mileages, try and get one with below 60,000. They will do 3 times that with careful servicing and a lot of replacement parts though.
5) signs of off roading. Get one that has never been off tarmac, there are plenty about if you look.
The following user(s) said Thank You: Sam_
- Sam_
- Visitor
19 Feb 2012 10:13 #33748
by Sam_
Replied by Sam_ on topic Re: Looking for my first Jimny!
Thanks for that Facade, off too look at my First one today.
But I think it's a bit high mileage for the price. nearly 4k and just under 80k miles but it's from a dealer so you always pay more!
- wanderinstar
- Visitor
19 Feb 2012 10:19 #33749
by wanderinstar
Replied by wanderinstar on topic Re: Looking for my first Jimny!
Funny that I s
traded my 03 Diesel Clio in for my 02 Jimny. Only regret is that the Jimny doesn't do 60+ to the gallon. Which is strange as the diesel Jimny uses the same Renault engine. Would I go back? No chance
- Sam_
- Visitor
19 Feb 2012 10:41 #33750
by Sam_
That was exactly what i wanted to hear!
My clio is the 1.2 petrol one so i'm not getting 60mpg anyways...
Only drive about 30miles a day so not that desperate for mega miles to the gallon.
19 Feb 2012 11:28 #33753
by facade
Forgot, check the front (and rear) tyres, they should wear flat. If there is one edge missing then either it has been driven very enthusiastically, or something is wrong with the steering.
Look for crash damage, usually cracked bumpers, jimnys normally crash big time and roll over, you won't miss signs of that The front chassis rails beneath the radiator are designed to crumple up in a crash, check they are straight.
If you get as far as driving it:
Check that the yellow engine light and the red seatbelt light come on with the ignition, and go off after a few seconds and stay off.
Listen for any loud whining noises or any vibration when you drive it. Check that all the gears work.
Take it upto 45 -50 -55 and see if the steering wheel stays still, if it starts to shake then it has the dreaded death wobble caused by worn swivel bearings and seals.
When standing still engine running, engage 4wd, the light on the dash should come on and stay on solid, if it doesn't come on or flashes something is wrong. Don't drive it in 4wd on tarmac though, this will break something.
- Sam_
- Visitor
19 Feb 2012 14:46 #33766
by Sam_
Well went and had a good look round it think it was a bit over priced actually done over 90k with no history apart from a print out of past MOT's.
Had slight rust on under the tool kit like you said, and when I opened the rad cap there was a slight hiss and I couldn't see any liquid in there at all!
Also when I started it, it wouldn't just start on the key. Had to give it a little throttle but once it started it ran fine.
Is that normal? they said it had last run on Friday.
Didn't take it for a drive but I'll know what to look for the next one I see.
- bluejimny
- Visitor
19 Feb 2012 15:06 #33769
by bluejimny
Replied by bluejimny on topic Re: Looking for my first Jimny!
ive had / 3 jimnys, got 2 and all have started straight away, hot or cold from one 42k one 67k one 118k
dont rush in, one will come up at the right price soon!
19 Feb 2012 17:28 #33777
by facade
Don't buy it :dry:
You want one that belonged to a little old lady who only drove it to the shops ( in 1st gear at 28mph with it in 4wd on dry tarmac :pinch: )
There will be loads about end of March early April, and they will be a lot less money when everyone has forgotten the snow and ice.
Please don't try the radiator cap test if the engine has been running :ohmy:
Most people look at the oil on the dipstick, if it is black and treacly, or plain not there it is a bad sign.
Take a look at the oil filter, if it is very rusty, or caked in 2 years worth of road grime it likely hasn't been changed recently.
- Sam_
- Visitor
20 Feb 2012 08:41 #33850
by Sam_
Yeah I won't be opening any radiator caps if the engine has been running!
want to get one sooner rather than later because...
1. I don't want my current car to deprecate to much.
and
2. I'm very impatient when It comes to cars! ha
was going to pop along to this place later www.concordegarage.co.uk/
Has anyone bought a jimny from there before? they seem to have lots in stock!
and
20 Feb 2012 08:54 #33851
Replied by mlines on topic Re: Looking for my first Jimny!
This is my "local" garage.
They are over-priced but if this is supported by a good warranty then that is worth something.
For example:
www.concordegarage.co.uk/used-cars/suzuk...ines-201102377103333
This is for a 53 plate, I just paid less than this for an immaculate 05 VVT with onlt 46,000 on the clock privately.
For example:
- Sam_
- Visitor
20 Feb 2012 09:03 #33852
by Sam_
I did think some of their prices were a little high, but I thought it might be a good place to compare several jimnys in one place.
I was thinking this is probably more my price range if I trade in my clio
www.concordegarage.co.uk/used-cars/suzuk...ines-201147431190074
that doesn't look too bad in price? for age/mileage does it?
Time to create page: 0.173 seconds
