Diff and Casings Breathers.
  • wanderinstar
30 Jan 2012 17:39 #32232 by wanderinstar
Diff and Casings Breathers. was created by wanderinstar
One of the next jobs I want to do is fit breather pipes to the diff and gearbox casings. I have seen some people screw fittings in. Is this an easy job. If not how secure are the bits of plastic pipe and jubilee clips?
  • myers647
30 Jan 2012 19:09 #32239 by myers647
Replied by myers647 on topic Re: Diff and Casings Breathers.
Hi mate , I bought my kit off ebay before it was available on this site. Its very easy to do, apart from the gear box and the transfer box which is just about impossible without removing it. Just mount the pipe ends in as high place as you can ie snorkel. Good important cheap mod.
Thanks
  • Dutchjimny
30 Jan 2012 20:43 #32252 by Dutchjimny
Replied by Dutchjimny on topic Re: Diff and Casings Breathers.
Is it easy to remove the transferbox and gearbox? maybe a howto?
  • supergaz
30 Jan 2012 20:43 - 30 Jan 2012 20:49 #32253 by supergaz
Replied by supergaz on topic Re: Diff and Casings Breathers.
Once the cap is prised off the diffs, then hose pipe will fit snug and tight, As supplied by Martin in the kits he supplies ( I have the same kit )
This is then reduced down with air hose couplings and air line to look tidy.
My SJ transfer case has had the breather drilled out, tapped and then a Air hose coupling screwed in, this is only possible with the casing opened up or the case will end up full of metal fragments.
Dutchjimny: The transfer case is easy to remove, but the gearbox is a big job.
Ian: Why don't you lower your transfer case down when you fit your KAP brackets? I'm sure the breather is the same as on the diffs so hose pipe will attach to it. The kits Martin has is perfect for the job.
Last edit: 30 Jan 2012 20:49 by supergaz.
  • wanderinstar
30 Jan 2012 21:50 #32260 by wanderinstar
Replied by wanderinstar on topic Re: Diff and Casings Breathers.
Yes Gary, will do that as I haven't fitted them yet. What sort of a job is gearbox. Can you get at it through top by removing gear lever gaiters?
  • 247sniper
31 Jan 2012 09:57 #32284 by 247sniper
Replied by 247sniper on topic Diff and Casings Breathers.
Jut a quicks guys, why would you want breathers on the duffs and gearbox ?
Steve.
Time to create page: 0.103 seconds
