Lumpy Cold Idle. Please help...
  • 247sniper
27 Jan 2012 12:45 #31977 by 247sniper
Replied by 247sniper on topic Re: Lumpy Cold Idle. Please help...
What you need to do is clean the EGR valve out, remove the throttle body and give in a good clean out including taking the idle air control valve out and cleaning and freeing that off too. Sounds like the EGR, IAC, or throttle postion sensor is giving the the ECU a false reading. Doing what I have suggested I'm sure will cure your problem. ( all easy enough to do yourself mate)
Steve.
  • 247sniper
27 Jan 2012 13:49 #31981 by 247sniper
Do you feel competent enough to tackle it mate ?
Steve.
  • 0202jimny
27 Jan 2012 18:15 #32002 by 0202jimny
Replied by 0202jimny on topic Re: Lumpy Cold Idle. Please help...
Thanks everyone, some great responses...
The car was used everyday for the school run, however the poor thing has never seen a spec of mud in its life....only some occasional snow. :)
Picked up some Wynn's injector cleaner today, so will put that through and see what happens... :/
Steve - that all sounds a bit daunting, but I'm sure ill be able to give it ago... :D
Charlie. :)
  • 247sniper
27 Jan 2012 20:06 #32011 by 247sniper
Don't worry mate it's only a few bolts and a few pipes really. Give us a shout if you get stuck fella and will be glad to help.
Steve.
  • Municipal Waste
28 Jan 2012 19:39 #32072 by Municipal Waste
Replied by Municipal Waste on topic Re: Lumpy Cold Idle. Please help...
I bet it's that bloody coolant temperature sensor that's causing all the problems :dry:
  • Rob Edge
30 Jan 2012 19:49 #32243 by Rob Edge
Replied by Rob Edge on topic Re: Lumpy Cold Idle. Please help...
Municipal Waste wrote: I bet it's that bloody coolant temperature sensor that's causing all the problems :dry:
I will bet your right aswell. Mine was doing this and that was the problem. The temp sensor tells the ecu it is at running temp and the ecu adjusts the IAC. If the sensor goes tits up the IAC will fluctuate. First case is disconnect the IAC plug and if it settles at around 1400rpm you can more or less guarantee it's the temp sensor.
Time to create page: 0.103 seconds
