Lumpy Cold Idle. Please help...
  • 0202jimny
26 Jan 2012 18:09 #31916 by 0202jimny
Lumpy Cold Idle. Please help... was created by 0202jimny
My 2002 Jimny 1.3 has only done 27,000 miles and things are now going wrong :(
On idle (when cold), the revs fluctuate between 1500rpm to just under 1000rpm, occasionally dropping to about 600rpm. When the revs get low it sounds like it is on the verge of dying if you don't give it some gas.
I gave it a motorway blast to try and solve it but the morning after there was no joy :(
After a bit of research I decided to change the PCV valve, but this has not done anything...
Thought this to be very odd as it only does it when cold...
This used to be my mums car so it's been in our family it's entire life and this is our very first mechanical problem in nearly 10 years!!!
Any help would be much appreciated :D
(p.s. i'm a first time poster)
26 Jan 2012 18:38 #31919 by Halford
Hi 0202jimny, welcome to the forum and world of Jimny ;)
Don't worry about it, it's probably just missing it's mum and will eventually settle down :silly:
when did it last have a service or any work done on it ?
does this only happen when it's cold or was it still doing it after the motorway blast - or was it only after starting when it had got cold again?
  • 0202jimny
26 Jan 2012 18:53 #31922 by 0202jimny
Replied by 0202jimny on topic Re: Lumpy Cold Idle. Please help...
Hi Halford,
I hope it isn't missing it's mum as i definately keep it cleaner than she did! :lol:
It was last serviced in October and had spark plugs changed, oil change etc. at our local kwik fit.
As soon as it gets up to temperature it runs perfectly, and it doesnt happen when it's started up whilst warm.
:S
Charlie
  • adamatdraycott
27 Jan 2012 07:05 #31958 by adamatdraycott
Replied by adamatdraycott on topic Re: Lumpy Cold Idle. Please help...
on 02 plate with only 27k on the clock... That car has been sat around for along time!
Maybe mucky injectors? Get some injector cleaner and give it a good run! Costs all of a few quid... might be worth a tank of premium fuel too!
Air inlet temp sensor on the airbox?
  • Monkey
27 Jan 2012 10:35 #31974 by Monkey
Replied by Monkey on topic Re: Lumpy Cold Idle. Please help...
Hi mate, Welcome to Big jimny.
Take the car to your local Suzuki dealer and get them to plug it into there computer ;) that will tell you straight away where the issue is. The only other thing i can think of is maybe a sticky/stuck EGR valve, that would cause the strange idle and missing.
Are there any dash light's coming on? Or is it throwing any error codes?
Andrew
  • p1ngu32
27 Jan 2012 11:05 #31976 by p1ngu32
Replied by p1ngu32 on topic Re: Lumpy Cold Idle. Please help...
I had this recently on a jimny i bought, was rough for the first 30 seconds or so, turned out to be the previous owner hadn't tightened up the spark plugs properly, im thinking the expansion when it warmed up was enough to make them seal, i changed the plugs and tightened them in properly and the problem went away completely. this was on a g13bb.
Time to create page: 0.092 seconds
