Snapped ignition key
  • Mala43B
13 Jan 2012 13:00 #30818 by Mala43B
Snapped ignition key was created by Mala43B
Hi guys
I've just went and snapped my ignition key and after a long walk home to get the spare I found out that it would not start the car. it would turn over but not start. I'm thinking the gray key must be an imobiliser key however I didn't think my Jimny had an imobliser fitted. (its an X reg 2001 Jimny JLX 4X4 without ABS).
For the life of me I don't know why I tried the following but it seemed to work and got the car started.
As I turned the spare key in the ignition I made sure the metal of the snapped key was touching the metal of the spare key and hay presto it started. I got home and tried it several more times and it worked again.
Is this right or am I missing something.
Also does anyone know how much a new key will cost from Suzuki in the UK.
  • vitara_mad
13 Jan 2012 13:24 #30819 by vitara_mad
Replied by vitara_mad on topic Re: Snapped ignition key
there is a chip in the grey key & there is a sensor that is on the ignition barrol behind the plastic suround
as long as you hold the grey plasic bit next to the ignition it will pick up the signal & allow you to start the car
that black key has no chip in it so you can't start it with just that key
  • reaper
13 Jan 2012 13:32 #30822 by reaper
Replied by reaper on topic Re: Snapped ignition key
i know a few people who have snaped the chiped key , most just tape the snaped key inside the cowling and leave it there
  • Mala43B
13 Jan 2012 13:33 #30823 by Mala43B
Replied by Mala43B on topic Re: Snapped ignition key
Ah right thanks. So as long as I've got both keys with me I'll be OK until I get a new key?
  • goatboy
13 Jan 2012 14:30 #30824 by goatboy
Replied by goatboy on topic Re: Snapped ignition key
yep, should be.
  • Mala43B
13 Jan 2012 14:33 #30825 by Mala43B
Thanks, It might have to do for a wile because no doubt new keys from Suzuki wont be cheap...!
