Snapped ignition key
  • darthloachie
13 Jan 2012 15:36 #30826 by darthloachie
Replied by darthloachie on topic Re: Snapped ignition key
you can get them elsewhere like key cutters who can copy the code if you take the broken key with you
prices vary between £20 and £60 but I'd imagine Suzuki would be much dearer (if its like fiat £200 :ohmy: )
  • Mala43B
13 Jan 2012 15:46 #30828 by Mala43B
Replied by Mala43B on topic Re: Snapped ignition key
I've only had my jimny 6 month so don't know for sure if both keys are the original keys supplied with the car but if they are whats is the point of a spare key that won't operate the imobiliser? I mean what if I had lost the key thinking I had a spare that would work.....!
  • darthloachie
13 Jan 2012 15:48 #30829 by darthloachie
some ones probably had it cut on the cheap with out the chip so they could sell it with two keys
  • Mala43B
13 Jan 2012 15:57 - 13 Jan 2012 15:59 #30831 by Mala43B
Yeah your probably right, Guess I should get two keys then....!
Last edit: 13 Jan 2012 15:59 by Mala43B.
  • russell
13 Jan 2012 16:46 #30840 by russell
Replied by russell on topic Re: Snapped ignition key
he past iv used the old snapped key by tieing it under the collum close to the ignition switch and just had a stardard key cut genrally the key only needs to be near the ignition barrel not metal to metal contact chiped keys can be very exspensive but this fix is cheap and dose work just an idea may hel you get back on the road
  • Mala43B
13 Jan 2012 17:12 #30844 by Mala43B
Cheers Russell, I've put both keys on the same key ring and it works so it'll do till I can get two new keys. I wouldn't want to leave the imobiliser key in the car...!
Time to create page: 0.782 seconds
