1 fault with the Jimny.
  • grumpy22
  • Visitor
  • Visitor
06 Jan 2012 22:26 #30194 by grumpy22
Replied by grumpy22 on topic Re: 1 fault with the Jimny.
Getting the plastic trim off is a bit of a confidence thing, the spring clips make you think it's still fixed in when it's not
I also took the small rubber strip fron the 'coin holder' and put that back on the other way up
I think the picture shows it well enough
  • Mala43B
  • Visitor
  • Visitor
15 Jan 2012 17:29 #30968 by Mala43B
Replied by Mala43B on topic Re: 1 fault with the Jimny.
I've done this mod and It's quite easy. here's a couple of pics.
Before:
After:
Plus I've attached a how to guide
Attachment clockina2001SuzukiJimny.pdf not found
for anyone else that would like to do it too.
  • grumpy22
  • Visitor
  • Visitor
15 Jan 2012 17:34 #30970 by grumpy22
you forgot to swap the rubber wedge in the 'coin tray. it's still on the top and pulls off easy and can be re-stuck onto the bottom. otherwise things slide out easily
nice guide, cheers
  • Mala43B
  • Visitor
  • Visitor
15 Jan 2012 17:47 #30974 by Mala43B
Doh..! ah well I never use the coin tray anyway.
  • reaper
  • Visitor
  • Visitor
15 Jan 2012 18:36 #30983 by reaper
Replied by reaper on topic Re: 1 fault with the Jimny.
Mala43B wrote: I've done this mod and It's quite easy. here's a couple of pics.
Before:
After:
are you sure this is a jimny and not a delorean ???? you seem to have finished a minuet earlier than you started :whistle:
  • Mala43B
  • Visitor
  • Visitor
15 Jan 2012 19:17 #30995 by Mala43B
Ha ha, didn't even notice the time on the clock. well I'm pretty sure its not a Delorean, god knows how bad the death wobble would be at the speed of light........!
  • wanderinstar
  • Visitor
  • Visitor
15 Jan 2012 21:47 #31022 by wanderinstar
Replied by wanderinstar on topic Re: 1 fault with the Jimny.
Excellent " How to Guide". However on mine,2002, there is a screw in the middle of the top of the facia. It is at the same angle as the bottom 2 screws.
Ian.
  • Mala43B
  • Visitor
  • Visitor
16 Jan 2012 16:18 #31070 by Mala43B
wanderinstar wrote: However on mine,2002, there is a screw in the middle of the top of the facia. It is at the same angle as the bottom 2 screws.
Ian.
Yeah it would seem that's right. Mine must of been missing and never noticed it. You can see the hole in the facia in the pics.
Time to create page: 0.211 seconds
