1 fault with the Jimny.
- wanderinstar
- Visitor
grumpy22 wrote: Yep that was me and my car, easy enough to do takes about an hour at the most.
Remove 3 screws and Pull off the facia, remove th screws and flip everything upside down. The only fiddly bit is shaving a lug off the clock so it can be turned round.
I take itt you didnt have the clock fitted upside down, only the housing.
- adamjimny
- Visitor
Sent from my GT-I9100 using Tapatalk
- wanderinstar
- Visitor
Horses for courses.
Ian.
- grumpy22
- Visitor
Easier to do than explain
- Goat
- Visitor
- Cider
- Visitor
Cheers
pete
- little jimny
- Visitor
wanderinstar wrote: if you do anything more than 50 you can get wobbles.
Something is wrong with it, likely worn out kingpin bearings and dust seals.
They do get blown around but without wind they drive straight (unless you have an uncorrected lift fitted)
- wanderinstar
- Visitor
Cant find these screws.Do you have to take the radio out first?
Ian.
Remove them, and then take the ashtray out, and remove the 2 self tappers upwards through the metal ashtray guide plate at the seat end.
The black part of the dash wrenches outwards at the bottom, but won't come out with the radio cage still fitted, so this has to be removed as well.
- wanderinstar
- Visitor
Grumpy 22 where are you,when i need you.
- supergaz
- Visitor
It's the easiest radio i've ever removed out of 1000's.
